Hello,
I tried to set up my openvpn client following these instructions, but it didn't work. Can anyone help me?
Instruction: https://www.perfect-privacy.com/en/manuals/router_asuswrtmerlin_openvpn
Log:
Apr 14 00:38:52 ovpn-client1[15477]: OpenVPN 2.4.7 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Apr 3 2019
Apr 14 00:38:52 ovpn-client1[15477]: library versions: OpenSSL 1.1.1b 26 Feb 2019, LZO 2.08
Apr 14 00:38:52 ovpn-client1[15478]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Apr 14 00:38:52 ovpn-client1[15478]: Outgoing Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Apr 14 00:38:52 ovpn-client1[15478]: Incoming Control Channel Authentication: Using 512 bit message hash 'SHA512' for HMAC authentication
Apr 14 00:38:52 ovpn-client1[15478]: LZO compression initializing
Apr 14 00:38:53 ovpn-client1[15478]: Control Channel MTU parms [ L:1626 D:1140 EF:110 EB:0 ET:0 EL:3 ]
Apr 14 00:38:53 ovpn-client1[15478]: Data Channel MTU parms [ L:1626 D:1300 EF:126 EB:407 ET:0 EL:3 ]
Apr 14 00:38:53 ovpn-client1[15478]: Fragmentation MTU parms [ L:1626 D:1300 EF:125 EB:407 ET:1 EL:3 ]
Apr 14 00:38:53 ovpn-client1[15478]: Local Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 1,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-client'
Apr 14 00:38:53 ovpn-client1[15478]: Expected Remote Options String (VER=V4): 'V4,dev-type tun,link-mtu 1606,tun-mtu 1500,proto UDPv4,comp-lzo,mtu-dynamic,keydir 0,cipher AES-256-CBC,auth SHA512,keysize 256,tls-auth,key-method 2,tls-server'
Apr 14 00:38:53 ovpn-client1[15478]: TCP/UDP: Preserving recently used remote address: [AF_INET]80.255.7.82:1151
Apr 14 00:38:53 ovpn-client1[15478]: Socket Buffers: R=[122880->122880] S=[122880->122880]
Apr 14 00:38:53 ovpn-client1[15478]: UDP link local: (not bound)
Apr 14 00:38:53 ovpn-client1[15478]: UDP link remote: [AF_INET]80.255.7.82:1151
Apr 14 00:38:53 ovpn-client1[15478]: TLS: Initial packet from [AF_INET]80.255.7.82:1151, sid=22c9d5e5 f9c43a0a
Apr 14 00:38:53 ovpn-client1[15478]: WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Apr 14 00:38:53 ovpn-client1[15478]: VERIFY OK: depth=1, C=CH, ST=Zug, L=Zug, O=Perfect Privacy, CN=Perfect Privacy, emailAddress=admin@perfect-privacy.com
Apr 14 00:38:53 ovpn-client1[15478]: VERIFY KU OK
Apr 14 00:38:53 ovpn-client1[15478]: Validating certificate extended key usage
Apr 14 00:38:53 ovpn-client1[15478]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Apr 14 00:38:53 ovpn-client1[15478]: VERIFY EKU OK
Apr 14 00:38:53 ovpn-client1[15478]: VERIFY OK: depth=0, C=CH, ST=Zug, O=Perfect Privacy, CN=Server_zurich.perfect-privacy.com, emailAddress=admin@perfect-privacy.com
Apr 14 00:39:01 ovpn-client1[15478]: Control Channel: TLSv1.2, cipher TLSv1.2 DHE-RSA-AES256-GCM-SHA384, 4096 bit RSA
Apr 14 00:39:01 ovpn-client1[15478]: [Server_zurich.perfect-privacy.com] Peer Connection Initiated with [AF_INET]80.255.7.82:1151
Apr 14 00:39:02 ovpn-client1[15478]: SENT CONTROL [Server_zurich.perfect-privacy.com]: 'PUSH_REQUEST' (status=1)
Apr 14 00:39:02 ovpn-client1[15478]: PUSH: Received control message: 'PUSH_REPLY,topology subnet,redirect-gateway def1,sndbuf 131072,rcvbuf 131072,comp-lzo adaptive,route-gateway 10.4.144.2,redirect-gateway ipv6,route-ipv6 2000::/3,ping 10,ping-restart 60,dhcp-option DNS 80.255.7.94,dhcp-option DNS 92.222.210.119,ifconfig-ipv6 fdbf:1d37:bbe0:0:73:8:0:f9/112 fdbf:1d37:bbe0:0:73:8:0:1,ifconfig 10.4.144.249 255.255.255.0,peer-id 9,cipher AES-256-GCM'
Apr 14 00:39:02 ovpn-client1[15478]: OPTIONS IMPORT: timers and/or timeouts modified
Apr 14 00:39:02 ovpn-client1[15478]: OPTIONS IMPORT: compression parms modified
Apr 14 00:39:02 ovpn-client1[15478]: LZO compression initializing
Apr 14 00:39:02 ovpn-client1[15478]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Apr 14 00:39:02 ovpn-client1[15478]: Socket Buffers: R=[122880->245760] S=[122880->245760]
Apr 14 00:39:02 ovpn-client1[15478]: OPTIONS IMPORT: --ifconfig/up options modified
Apr 14 00:39:02 ovpn-client1[15478]: OPTIONS IMPORT: route options modified
Apr 14 00:39:02 ovpn-client1[15478]: OPTIONS IMPORT: route-related options modified
Apr 14 00:39:02 ovpn-client1[15478]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Apr 14 00:39:02 ovpn-client1[15478]: OPTIONS IMPORT: peer-id set
Apr 14 00:39:02 ovpn-client1[15478]: OPTIONS IMPORT: adjusting link_mtu to 1629
Apr 14 00:39:02 ovpn-client1[15478]: OPTIONS IMPORT: data channel crypto options modified
Apr 14 00:39:02 ovpn-client1[15478]: Data Channel: using negotiated cipher 'AES-256-GCM'
Apr 14 00:39:02 ovpn-client1[15478]: Data Channel MTU parms [ L:1557 D:1300 EF:57 EB:407 ET:0 EL:3 ]
Apr 14 00:39:02 ovpn-client1[15478]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Apr 14 00:39:02 ovpn-client1[15478]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Apr 14 00:39:02 ovpn-client1[15478]: GDG6: remote_host_ipv6=n/a
Apr 14 00:39:02 ovpn-client1[15478]: TUN/TAP device tun11 opened
Apr 14 00:39:02 ovpn-client1[15478]: TUN/TAP TX queue length set to 1000
Apr 14 00:39:02 ovpn-client1[15478]: do_ifconfig, tt->did_ifconfig_ipv6_setup=1
Apr 14 00:39:02 ovpn-client1[15478]: /usr/sbin/ip link set dev tun11 up mtu 1500
Apr 14 00:39:02 ovpn-client1[15478]: /usr/sbin/ip addr add dev tun11 10.4.144.249/24 broadcast 10.4.144.255
Apr 14 00:39:02 ovpn-client1[15478]: /usr/sbin/ip -6 addr add fdbf:1d37:bbe0:0:73:8:0:f9/112 dev tun11
Apr 14 00:39:02 ovpn-client1[15478]: Linux ip -6 addr add failed: external program exited with error status: 2
Apr 14 00:39:02 ovpn-client1[15478]: Exiting due to fatal error
Log:
