tooandrew
i have two different rt-ac66u model routers, both running the same merlin build. (i just updated the build on one of them to attempt to fix this) everything was working spectacularly until just recently, when i started seeing SIGUSR1[SOFT] errors, now it refuses to stay connected on my shield tv.
this is my client's log
And the routers log
anyone who might be able to help me out here?
OpenVPN 2.3.6 android-armeabi [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on May 14 2015
library versions: OpenSSL 1.0.2a 19 Mar 2015, LZO 2.08
UDPv4 link local (bound): [undef]
UDPv4 link remote: [AF_INET]24.98.6.226:1194
[RT-AC66U] Peer Connection Initiated with [AF_INET]192.168.1.1:1194
TUN/TAP device opened
Initialization Sequence Completed
DHCP client started
DHCP client completed
TapEmulator started
SIGUSR1[soft,] received, process restarting
TapEmulator stopped
SIGUSR1[soft,init_instance] received, process restarting
DHCP client started
TapEmulator started
TapEmulator stopped
SIGINT[soft,init_instance] received, process exiting
DHCP client started
TapEmulator started
TapEmulator stopped
DHCP client started
TapEmulator started
TapEmulator stopped
And the routers log
Jun 14 00:09:03 openvpn[563]: client/192.168.1.163:1194 TLS: new session incoming connection from [AF_INET]192.168.1.163:1194
Jun 14 00:09:03 openvpn[563]: client/192.168.1.163:1194 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC66U, emailAddress=me@myhost.mydomain
Jun 14 00:09:03 openvpn[563]: client/192.168.1.163:1194 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, CN=client, emailAddress=me@myhost.mydomain
Jun 14 00:09:03 openvpn[563]: client/192.168.1.163:1194 PLUGIN_CALL: POST /usr/lib/openvpn-plugin-auth-pam.so/PLUGIN_AUTH_USER_PASS_VERIFY status=0
Jun 14 00:09:03 openvpn[563]: client/192.168.1.163:1194 TLS: Username/Password authentication succeeded for username 'alex'
Jun 14 00:09:03 openvpn[563]: client/192.168.1.163:1194 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Jun 14 00:09:03 openvpn[563]: client/192.168.1.163:1194 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jun 14 00:09:03 openvpn[563]: client/192.168.1.163:1194 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Jun 14 00:09:03 openvpn[563]: client/192.168.1.163:1194 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jun 14 00:09:03 openvpn[563]: client/192.168.1.163:1194 TLS: move_session: dest=TM_ACTIVE src=TM_UNTRUSTED reinit_src=1
Jun 14 00:09:03 openvpn[563]: client/192.168.1.163:1194 TLS: tls_multi_process: untrusted session promoted to semi-trusted
Jun 14 00:09:03 openvpn[563]: client/192.168.1.163:1194 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Jun 14 00:09:05 openvpn[563]: client/192.168.1.163:1194 PUSH: Received control message: 'PUSH_REQUEST'
Jun 14 00:09:05 openvpn[563]: client/192.168.1.163:1194 send_push_reply(): safe_cap=940
Jun 14 00:09:05 openvpn[563]: client/192.168.1.163:1194 SENT CONTROL [client]: 'PUSH_REPLY,route 0.0.0.0 255.255.255.255 net_gateway,dhcp-option DNS 192.168.1.1,route-gateway 192.168.1.1,redirect-gateway def1,route-gateway dhcp,ping 15,ping-restart 60' (status=1)
Jun 14 00:09:05 dnsmasq-dhcp[426]: DHCPDISCOVER(br0) 00:16:3e:4f:f9:54
Jun 14 00:09:05 dnsmasq-dhcp[426]: DHCPOFFER(br0) 192.168.1.34 00:16:3e:4f:f9:54
Jun 14 00:09:05 dnsmasq-dhcp[426]: DHCPREQUEST(br0) 192.168.1.34 00:16:3e:4f:f9:54
Jun 14 00:09:05 dnsmasq-dhcp[426]: DHCPACK(br0) 192.168.1.34 00:16:3e:4f:f9:54 0163e4ff954
Jun 14 00:09:09 openvpn[563]: client/192.168.1.163:1194 TLS: new session incoming connection from [AF_INET]192.168.1.163:1194
Jun 14 00:09:09 openvpn[563]: client/192.168.1.163:1194 VERIFY OK: depth=1, C=TW, ST=TW, L=Taipei, O=ASUS, CN=RT-AC66U, emailAddress=me@myhost.mydomain
Jun 14 00:09:09 openvpn[563]: client/192.168.1.163:1194 VERIFY OK: depth=0, C=TW, ST=TW, L=Taipei, O=ASUS, CN=client, emailAddress=me@myhost.mydomain
Jun 14 00:09:09 openvpn[563]: client/192.168.1.163:1194 PLUGIN_CALL: POST /usr/lib/openvpn-plugin-auth-pam.so/PLUGIN_AUTH_USER_PASS_VERIFY status=0
Jun 14 00:09:09 openvpn[563]: client/192.168.1.163:1194 TLS: Username/Password authentication succeeded for username 'alex'
Jun 14 00:09:09 openvpn[563]: client/192.168.1.163:1194 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Jun 14 00:09:09 openvpn[563]: client/192.168.1.163:1194 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jun 14 00:09:09 openvpn[563]: client/192.168.1.163:1194 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Jun 14 00:09:09 openvpn[563]: client/192.168.1.163:1194 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jun 14 00:09:09 openvpn[563]: client/192.168.1.163:1194 TLS: move_session: dest=TM_ACTIVE src=TM_UNTRUSTED reinit_src=1
Jun 14 00:09:09 openvpn[563]: client/192.168.1.163:1194 TLS: tls_multi_process: untrusted session promoted to semi-trusted
Jun 14 00:09:09 openvpn[563]: client/192.168.1.163:1194 Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Jun 14 00:09:11 openvpn[563]: client/192.168.1.163:1194 PUSH: Received control message: 'PUSH_REQUEST'
Jun 14 00:09:16 openvpn[563]: client/192.168.1.163:1194 PUSH: Received control message: 'PUSH_REQUEST'
