Hi ALL
I have RT-AC66U with Firmware Version 3.0.0.4.374.726 and ADSL modem.
If I configure RT-AC66U to use Dynamic IP from ISP than router goes in permanent reboot. It looks like
- router started
- wifi started (i can access to router console)
- negotiation with ISP happened (i see by activity in ADSL modem)
- IP is assigned (i see it in router log)
- after few seconds all lights on router are splashed and cycle repeats.
It continues until i switch off ADSL modem. With switched off ADSL router starts and works normally. If than switch ADSL again on than reboot starts.
But if i configure router to use Static IP (same which i saw in log ) than all is Ok - no any reboots, intranet works, Internet also works.
There is also no any problems when i use USB modem in Dual WAN even with Dynamic IP. Laptop connected directly to ADSL by cable works properly and see Internet.
Router hard reset and clear configuration with default settings dont change anything.
There is also no any additional devices like USB disks connected to router.
Can you give me some advise or vision where the problem can be ?
- router started
