Bill_Stewart
I have an RT-AC66U B1 and have updated the firmware to ASUSWRT 3.0.0.4.386_40558.
My network configuration is as follows:
(TL-PA7010P are AV1000 powerline adapters)
I have an older RT-ACRH13 that works fine in this configuration.
When I put the RT-AC66U B1 in this configuration (using the same IP configuration as the RT-ACRH13), the LAN interface behaves very strangely: I get a few ping responses while it is booting, but then all pings after that time out.
Oddly, I can ping the LAN interface on the DSL modem, the connected VoIP device interface and other connected interfaces on the network, but not the LAN interface on the RT-AC66U B1. Since the LAN interface on the DSL modem requires the LAN on the RT-AC66U B1 in this configuration, there is no Internet connectivity.
Again: The RT-ACRH13 router I am using in the above configuration works flawlessly and there are no issues -- it's been rock-solid since I've set up the above configuration nearly a year ago. But the RT-AC66U B1 is thus far unusable.
Any ideas on what's going on?
