chikavelja
Hello guys!
I was wondering, has anyone tried to mount the RT-AC66U (or N66U) upside down?
I'm planning on mounting it on the small network cabinet which is on the ceiling, it would be upside down.
Now, the physics says that the heat shoud go upwards and theoretically this would be an ideal position since the airflow holes are on the bottom meaning they would be turned upwards.
Thank you for your comments!
