rt-ac66u overclock
blueis300
Some may say why and its basically just for information. I see all kinds of information on the n56u I think about running the cpu higher but the memory cant do much or certain routers cant because the cfe firmware. I know the stock is 600,300,150. Stock on the rt-n56u seems much higher. Ive read the reasons why but havent found any specific thread for the ac66u. Forgive me if my search skills suck. Also just looking for the best setting for range. I have read about what channel and seeing what my neighbors are running. I have a 2 story house with 2 computers hard wired, my ooma , synology ds214play, 2 computers wireless and 2 printers.
I will also have to check out the forums for the setup on the Synology as this is all a learning experience. A lot of reading and a lot of trial and error. Sorry that this may also many questions about several different questions. I am currently runnong Merlin 3.0.0.4.374.39
1. Just for knowledge best settings ability to overclock
2. Best settings for my situation with connected devices
3. Direction for settings for the Synology
Thanks for the link. I also read if not using 5 ghz to disable as Im not using it. I have mine set to N at 40mhz. Guess I should change that. I have my tx level at 120. It says I have my cpu frequency set at 675 but as I read it could be an inaccurate ready. I will read up on those links. Thanks.
