I'm now on my second AC66U for this same issue. ASUS support has been no help at all. New AC66U and new comcast bridged gateway installed today, flashed to latest firmware, and within 10 minutes it started rebooting every 10 to 15 minutes. I'm at my wits end trying to fix this. Help please!
syslog after each reboot is as follows:
Dec 31 19:00:11 syslogd started: BusyBox v1.17.4
Dec 31 19:00:11 kernel: klogd started: BusyBox v1.17.4 (2015-01-10 19:34:47 CST)
Dec 31 19:00:11 kernel: start_kernel
Dec 31 19:00:11 kernel: Linux version 2.6.22.19 (root@asus) (gcc version 4.2.3) #1 Sat Jan 10 19:37:50 CST 2015
Dec 31 19:00:11 kernel: CPU revision is: 00019749
Dec 31 19:00:11 kernel: Found an ST compatible serial flash with 32 64KB blocks; total size 2MB
Dec 31 19:00:11 kernel: Determined physical RAM map:
Dec 31 19:00:11 kernel: memory: 07fff000 @ 00000000 (usable)
Dec 31 19:00:11 kernel: memory: 08000000 @ 87fff000 (usable)
Dec 31 19:00:11 kernel: Built 1 zonelists. Total pages: 585216
Dec 31 19:00:11 kernel: Kernel command line: root=/dev/mtdblock3 console=ttyS0,115200 init=/sbin/preinit
Dec 31 19:00:11 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Dec 31 19:00:11 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Dec 31 19:00:11 kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Dec 31 19:00:11 kernel: CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Dec 31 19:00:11 kernel: Using 300.000 MHz high precision timer.
Dec 31 19:00:11 syslog: module ledtrig-usbdev not found in modules.dep
Dec 31 19:00:11 syslog: module leds-usb not found in modules.dep
Dec 31 19:00:11 kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Dec 31 19:00:11 kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Dec 31 19:00:11 kernel: Mount-cache hash table entries: 512
Dec 31 19:00:11 kernel: PCI: Initializing host
Dec 31 19:00:12 kernel: PCI: Reset RC
Dec 31 19:00:12 kernel: PCI: Initializing host
Dec 31 19:00:12 kernel: PCI: Fixing up bus 0
Dec 31 19:00:12 kernel: PCI/PCIe coreunit 0 is set to bus 1.
Dec 31 19:00:12 kernel: PCI: Fixing up bridge
Dec 31 19:00:12 kernel: PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
Dec 31 19:00:12 kernel: PCI: Fixing up bus 1
Dec 31 19:00:12 kernel: PCI/PCIe coreunit 1 is set to bus 2.
Dec 31 19:00:12 kernel: PCI: Enabling device 0000:02:00.1 (0004 -> 0006)
Dec 31 19:00:12 kernel: PCI: Fixing up bus 2
Dec 31 19:00:12 kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Dec 31 19:00:12 kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Dec 31 19:00:12 kernel: TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
Dec 31 19:00:12 kernel: highmem bounce pool size: 64 pages
Dec 31 19:00:12 kernel: pflash: found no supported devices
Dec 31 19:00:12 kernel: Boot partition size = 262144(0x40000)
Dec 31 19:00:12 kernel: Creating 2 MTD partitions on "sflash":
Dec 31 19:00:12 kernel: 0x00000000-0x00040000 : "pmon"
Dec 31 19:00:12 kernel: 0x001f0000-0x00200000 : "nvram"
Dec 31 19:00:12 kernel: Found a Zentel NAND flash with 2048B pages or 128KB blocks; total size 128MB
Dec 31 19:00:12 kernel: lookup_nflash_rootfs_offset: offset = 0x0
Dec 31 19:00:12 kernel: nflash: squash filesystem with lzma found at block 9
Dec 31 19:00:12 kernel: Creating 4 MTD partitions on "nflash":
Dec 31 19:00:12 kernel: 0x00000000-0x02000000 : "linux"
Dec 31 19:00:12 kernel: 0x00134ec0-0x02000000 : "rootfs"
Dec 31 19:00:12 kernel: 0x04000000-0x06000000 : "linux2"
Dec 31 19:00:12 kernel: 0x04134ec0-0x06000000 : "rootfs2"
Dec 31 19:00:12 kernel: Creating 3 MTD partitions on "brcmnand":
Dec 31 19:00:12 kernel: 0x00000000-0x02000000 : "trx"
Dec 31 19:00:12 kernel: 0x04000000-0x06000000 : "asustrx2"
Dec 31 19:00:12 kernel: 0x06000000-0x07f00000 : "brcmnand"
Dec 31 19:00:12 kernel: dev_nvram_init: _nvram_init
Dec 31 19:00:12 kernel: u32 classifier
Dec 31 19:00:12 kernel: OLD policer on
Dec 31 19:00:12 kernel: Netfilter messages via NETLINK v0.30.
Dec 31 19:00:12 kernel: nf_conntrack version 0.5.0 (2048 buckets, 16384 max)
Dec 31 19:00:12 kernel: ipt_time loading
Dec 31 19:00:12 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 19:00:12 kernel: net/ipv4/netfilter/tomato_ct.c [Jan 10 2015 19:37:13]
Dec 31 19:00:12 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Dec 31 19:00:12 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Dec 31 19:00:12 kernel: Warning: unable to open an initial console.
Dec 31 19:00:12 kernel: Failed to execute /sbin/preinit. Attempting defaults...
Dec 31 19:00:12 kernel: Algorithmics/MIPS FPU Emulator v1.5
Dec 31 19:00:12 kernel: et: module license 'Proprietary' taints kernel.
Dec 31 19:00:12 kernel: et_module_init: passivemode set to 0x0
Dec 31 19:00:12 kernel: et_module_init: et_txq_thresh set to 0x400
Dec 31 19:00:12 kernel: bcm_robo_enable_switch: EEE is disabled
Dec 31 19:00:12 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.163.2002 (r382208)
Dec 31 19:00:12 kernel: wl_module_init: passivemode set to 0x0
Dec 31 19:00:12 kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
Dec 31 19:00:12 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Dec 31 19:00:12 kernel: PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
Dec 31 19:00:12 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.30.163.2002 (r382208)
Dec 31 19:00:12 kernel: SCSI subsystem initialized
Dec 31 19:00:12 kernel: ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c01f8000
Dec 31 19:00:12 kernel: NTFS (with native replay) support included
Dec 31 19:00:12 kernel: optimized: speed
Dec 31 19:00:12 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Dec 31 19:00:15 kernel: wlc_phy_cal_init_acphy: NOT Implemented
Dec 31 19:00:15 stop_nat_rules: apply the redirect_rules!
Dec 31 19:00:15 WAN Connection: ISP's DHCP did not function properly.
Dec 31 19:00:21 dnsmasq[353]: warning: interface ppp1* does not currently exist
Dec 31 19:00:21 RT-AC66U: start httpd
Dec 31 19:00:21 syslog: Generating SSL certificate...
Dec 31 19:00:21 disk monitor: be idle
Dec 31 19:00:23 start_nat_rules: apply the nat_rules(/tmp/nat_rules_eth0_eth0)!
Dec 31 19:00:24 kernel: nf_conntrack_rtsp v0.6.21 loading
Dec 31 19:00:24 kernel: nf_nat_rtsp v0.6.21 loading
Dec 31 19:00:25 rc_service: udhcpc 397:notify_rc stop_upnp
Dec 31 19:00:25 rc_service: udhcpc 397:notify_rc start_upnp
Dec 31 19:00:25 WAN Connection: WAN was restored.
Dec 31 19:00:28 ntp: start NTP update
Jan 17 14:16:41 rc_service: ntp 447:notify_rc restart_upnp
Jan 17 14:16:41 rc_service: ntp 447:notify_rc restart_diskmon
Jan 17 14:16:41 rc_service: waitting "restart_upnp" via ntp ...
Jan 17 14:16:42 disk monitor: be idle
Jan 17 14:16:42 dhcp client: bound 50.160.146.79 via 50.160.144.1 during 341321 seconds.
Jan 17 14:17:14 crond[356]: time disparity of 2128036 minutes detected
Jan 17 14:30:23 kernel: eth1: received packet with own address as source address
