I have an AC66u, and I have a issue where we have to restart the router every so often. I have included the logfile in hopes that I can figure out if it is the ISP (Cox) or maybe the Server handing out the DHCP? Any advice would be appreciated.
Dec 1 00:00:28 syslogd started: BusyBox v1.20.2
Dec 1 00:00:28 kernel: klogd started: BusyBox v1.20.2 (2015-02-06 20:45:04 EST)
Dec 1 00:00:28 kernel: start_kernel
Dec 1 00:00:28 kernel: Linux version 2.6.22.19 (root@asus) (gcc version 4.2.3) #1 Fri Feb 6 20:46:21 EST 2015
Dec 1 00:00:28 kernel: CPU revision is: 00019749
Dec 1 00:00:28 kernel: Found an ST compatible serial flash with 32 64KB blocks; total size 2MB
Dec 1 00:00:28 kernel: Determined physical RAM map:
Dec 1 00:00:28 kernel: memory: 07fff000 @ 00000000 (usable)
Dec 1 00:00:28 kernel: memory: 08000000 @ 87fff000 (usable)
Dec 1 00:00:29 kernel: Built 1 zonelists. Total pages: 585216
Dec 1 00:00:29 kernel: Kernel command line: root=/dev/mtdblock3 console=ttyS0,115200 init=/sbin/preinit
Dec 1 00:00:29 kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Dec 1 00:00:29 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Dec 1 00:00:29 kernel: Synthesized TLB refill handler (20 instructions).
Dec 1 00:00:29 kernel: Synthesized TLB load handler fastpath (32 instructions).
Dec 1 00:00:29 kernel: Synthesized TLB store handler fastpath (32 instructions).
Dec 1 00:00:29 kernel: Synthesized TLB modify handler fastpath (31 instructions).
Dec 1 00:00:29 kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Dec 1 00:00:29 kernel: CPU: BCM5300 rev 1 pkg 0 at 600 MHz
Dec 1 00:00:29 kernel: Using 300.000 MHz high precision timer.
Dec 1 00:00:29 kernel: console [ttyS0] enabled
Dec 1 00:00:29 kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Dec 1 00:00:29 kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Dec 1 00:00:29 kernel: Memory: 238352k/131068k available (2665k kernel code, 22808k reserved, 534k data, 200k init, 131072k highmem)
Dec 1 00:00:29 kernel: Mount-cache hash table entries: 512
Dec 1 00:00:29 kernel: NET: Registered protocol family 16
Dec 1 00:00:29 kernel: PCI: Initializing host
Dec 1 00:00:29 syslog: module ledtrig-usbdev not found in modules.dep
Dec 1 00:00:30 kernel: PCI: Reset RC
Dec 1 00:00:30 kernel: PCI: Initializing host
Dec 1 00:00:30 kernel: PCI: Fixing up bus 0
Dec 1 00:00:30 kernel: PCI/PCIe coreunit 0 is set to bus 1.
Dec 1 00:00:30 kernel: PCI: Fixing up bridge
Dec 1 00:00:30 kernel: PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
Dec 1 00:00:30 kernel: PCI: Fixing up bus 1
Dec 1 00:00:30 kernel: PCI/PCIe coreunit 1 is set to bus 2.
Dec 1 00:00:30 syslog: module leds-usb not found in modules.dep
Dec 1 00:00:30 kernel: PCI: Enabling device 0000:02:00.1 (0004 -> 0006)
Dec 1 00:00:30 kernel: PCI: Fixing up bus 2
Dec 1 00:00:30 kernel: NET: Registered protocol family 2
Dec 1 00:00:30 kernel: Time: MIPS clocksource has been installed.
Dec 1 00:00:30 kernel: IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
Dec 1 00:00:30 kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Dec 1 00:00:30 kernel: TCP bind hash table entries: 16384 (order: 4, 65536 bytes)
Dec 1 00:00:30 kernel: TCP: Hash tables configured (established 16384 bind 16384)
Dec 1 00:00:30 kernel: TCP reno registered
Dec 1 00:00:30 kernel: highmem bounce pool size: 64 pages
Dec 1 00:00:30 kernel: squashfs: version 3.2-r2 (2007/01/15) Phillip Lougher
Dec 1 00:00:30 kernel: io scheduler noop registered (default)
Dec 1 00:00:30 kernel: HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
Dec 1 00:00:30 kernel: N_HDLC line discipline registered.
Dec 1 00:00:30 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
Dec 1 00:00:30 kernel: serial8250: ttyS0 at MMIO 0x0 (irq = 8) is a 16550A
Dec 1 00:00:30 kernel: serial8250: ttyS1 at MMIO 0x0 (irq = 8) is a 16550A
Dec 1 00:00:30 kernel: PPP generic driver version 2.4.2
Dec 1 00:00:30 kernel: MPPE/MPPC encryption/compression module registered
Dec 1 00:00:30 kernel: NET: Registered protocol family 24
Dec 1 00:00:30 kernel: PPPoL2TP kernel driver, V0.18.3
Dec 1 00:00:30 kernel: PPTP driver version 0.8.5
Dec 1 00:00:30 kernel: pflash: found no supported devices
Dec 1 00:00:30 kernel: Boot partition size = 262144(0x40000)
Dec 1 00:00:30 kernel: Creating 2 MTD partitions on "sflash":
Dec 1 00:00:30 kernel: 0x00000000-0x00040000 : "pmon"
Dec 1 00:00:30 kernel: 0x001f0000-0x00200000 : "nvram"
Dec 1 00:00:30 kernel: Found a Zentel NAND flash with 2048B pages or 128KB blocks; total size 128MB
Dec 1 00:00:30 kernel: lookup_nflash_rootfs_offset: offset = 0x0
Dec 1 00:00:30 kernel: nflash: squash filesystem with lzma found at block 9
Dec 1 00:00:30 kernel: Creating 2 MTD partitions on "nflash":
Dec 1 00:00:30 kernel: 0x00000000-0x02000000 : "linux"
Dec 1 00:00:30 kernel: 0x0013d1d0-0x02000000 : "rootfs"
Dec 1 00:00:30 kernel: NAND device: Manufacturer ID: 0x92, Chip ID: 0xf1 (Zentel NAND 128MiB 3,3V 8-bit)
Dec 1 00:00:30 kernel: Creating 3 MTD partitions on "brcmnand":
Dec 1 00:00:30 kernel: 0x00000000-0x02000000 : "trx"
Dec 1 00:00:30 kernel: 0x02000000-0x04000000 : "jffs2"
Dec 1 00:00:30 kernel: 0x04000000-0x07f00000 : "brcmnand"
Dec 1 00:00:30 kernel: dev_nvram_init: _nvram_init
Dec 1 00:00:30 kernel: sdhci: Secure Digital Host Controller Interface driver
Dec 1 00:00:30 kernel: sdhci: Copyright(c) Pierre Ossman
Dec 1 00:00:30 kernel: u32 classifier
Dec 1 00:00:30 kernel: OLD policer on
Dec 1 00:00:30 kernel: Netfilter messages via NETLINK v0.30.
Dec 1 00:00:30 kernel: nf_conntrack version 0.5.0 (2048 buckets, 16384 max)
Dec 1 00:00:30 kernel: ipt_time loading
Dec 1 00:00:30 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Dec 1 00:00:30 kernel: net/ipv4/netfilter/tomato_ct.c [Feb 6 2015 20:46:20]
Dec 1 00:00:30 kernel: ipt_account 0.1.21 : Piotr Gasidlo <quaker@barbara.eu.org>, http://code.google.com/p/ipt-account/
Dec 1 00:00:30 kernel: NET: Registered protocol family 1
Dec 1 00:00:30 kernel: NET: Registered protocol family 10
Dec 1 00:00:30 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Dec 1 00:00:30 kernel: NET: Registered protocol family 17
Dec 1 00:00:30 kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Dec 1 00:00:30 kernel: All bugs added by David S. Miller <davem@redhat.com>
Dec 1 00:00:30 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Dec 1 00:00:30 kernel: Freeing unused kernel memory: 200k freed
Dec 1 00:00:30 kernel: Warning: unable to open an initial console.
Dec 1 00:00:30 kernel: Failed to execute /sbin/preinit. Attempting defaults...
Dec 1 00:00:30 kernel: Algorithmics/MIPS FPU Emulator v1.5
Dec 1 00:00:30 kernel: ctf: module license 'Proprietary' taints kernel.
Dec 1 00:00:30 kernel: et_module_init: passivemode set to 0x0
Dec 1 00:00:30 kernel: et_module_init: et_txq_thresh set to 0x400
Dec 1 00:00:30 kernel: bcm_robo_enable_switch: EEE is disabled
Dec 1 00:00:30 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.163.2002 (r382208)
Dec 1 00:00:30 kernel: wl_module_init: passivemode set to 0x0
Dec 1 00:00:30 kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
Dec 1 00:00:30 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Dec 1 00:00:30 kernel: PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
Dec 1 00:00:30 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.30.163.2002 (r382208)
Dec 1 00:00:30 kernel: JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
Dec 1 00:00:30 kernel: usbcore: registered new interface driver usbfs
Dec 1 00:00:30 kernel: usbcore: registered new interface driver hub
Dec 1 00:00:30 kernel: usbcore: registered new device driver usb
Dec 1 00:00:30 kernel: SCSI subsystem initialized
Dec 1 00:00:30 kernel: Initializing USB Mass Storage driver...
Dec 1 00:00:30 kernel: usbcore: registered new interface driver usb-storage
Dec 1 00:00:30 kernel: USB Mass Storage support registered.
Dec 1 00:00:31 kernel: ufsd: driver (8.6 U86_r187446_b122, LBD=ON, acl, ioctl, rwm, ws, sd) loaded at c027d000
Dec 1 00:00:31 kernel: NTFS (with native replay) support included
Dec 1 00:00:31 kernel: optimized: speed
Dec 1 00:00:31 kernel: Build_for__asus_n66u_2011-10-27_U86_r187446_b122
Dec 1 00:00:31 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Dec 1 00:00:31 kernel: ehci_hcd 0000:00:04.1: EHCI Host Controller
Dec 1 00:00:31 kernel: ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
Dec 1 00:00:31 kernel: ehci_hcd 0000:00:04.1: EHCI Fastpath: New EHCI driver starting
Dec 1 00:00:32 kernel: ehci_hcd 0000:00:04.1: irq 6, io mem 0x18004000
Dec 1 00:00:32 kernel: ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
Dec 1 00:00:32 kernel: usb usb1: configuration #1 chosen from 1 choice
Dec 1 00:00:32 kernel: hub 1-0:1.0: USB hub found
Dec 1 00:00:32 kernel: hub 1-0:1.0: 2 ports detected
Dec 1 00:00:32 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Dec 1 00:00:32 kernel: ohci_hcd 0000:00:04.0: OHCI Host Controller
Dec 1 00:00:32 kernel: ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2
Dec 1 00:00:32 kernel: ohci_hcd 0000:00:04.0: irq 6, io mem 0x18009000
Dec 1 00:00:32 kernel: usb usb2: configuration #1 chosen from 1 choice
