Hi, friends,
I have some problem, when I connect USB flash(Sandisk Cruzer fit 8G) / HDD(Segate portable 2TB hdd[2 partition]) together.
First, I connect USB flash at USB 2.0 port, and it mounted '/dev/sda1' when check putty(SSH). Then, install optware with perfect tutorial of 'TeHashX'.
Second, I connect USB HDD at USB 3.0 port, all connected storages appear 'unmounted' at ASUS management page(192.168.1.1). When I check at putty with 'mount', it suprisingly display like below.
- USB flash of 2.0 port : /dev/sdc1 (It wase changed automatically and not operated 'Transmission' too)
- USB HDD of 3.0 port : /dev/sdb1 and /dev/sdb2
Why happen this problem... If I connect USB flash to 3.0 port, it's ok.(It always mounted '/dev/sda1', but it 's not enough for me.)
Is there a way to solve this problem? I already spend many times to solve it....But, I can't do it..(including "http://forums.smallnetbuilder.com/showpost.php?p=59842&postcount=5")
Thanks in advance for your feedback.
