Hello, question for you, the default power level on this router is maximum (100%). My understanding with RF power (Radio Frequency) is that you should use the lowest power possible to get the job done. Why would Asus use 100% as default? I am thinking that the technology may throttle (reduce) the power when needed ? Not real sure. Anyone know exactly how this is supposed to work or should the end users continue to follow the standard protocol of reducing the power level to the minimum needed. Running the latest firmware BTW.
