[RT-AC68U // 378.56_2] Lan > Switch Control > NAT Acceleration
muffintastic
Hello.
I'm encountering a very weird problem. When I set it to 'Auto' I can connect to the Black Ops 3 III servers; Where it checks files/downloads and verifies them as standard, but I lose half my bandwidth, when I disable this feature I am just stuck on the "Connecting..." I am connected to Xbox Live in both tests, ALL ports that are required are open also.
I have noticed when I have it set to disabled some website fail to load even though I know they work and you guessed it, I set it to Auto and works again.
I would rather have it disabled and have the full bandwidth, QOS is disabled across the router so I know it's nothing to do with that. Could someone advise me what the issue or have encountered this weirdness before?
