Just confirmed this and my AiCloud is disabled. I believe Samba Share is enabled by default under USB application-->Servers Center but probably not related to this.I have never seen the AiCloud services enabled on my routers. My AX88U Pro has always defaulted to disabled on ASUS stock firmware.
Well got the omada installed. gatewat 192.168.1.1 (default was 192.168.0.1)By the way, if you are going to use Omada SDN and not stand alone GUI - Omada doesn't require local hardware/software controller anymore. There is a new Omada Cloud-Based Controller option with free account. Somewhat limited in features, but can save $100 in hardware.
With the Omada Cloud-Based Controller entirely in the cloud, Omada Cloud SDN offers zero-touch provisioning for efficient and affordable deployment and provides centralized management of the network, including access points, switches, and routers.www.tp-link.com
Can you continue this conversation in a different thread please rather than hijacking this one. Thanks.Well got the omada installed. gatewat 192.168.1.1 (default was 192.168.0.1)
BUT whenever I try to adpot it in the omada cloud or through the controller in a docker container it wipes the router back to its defaults 192.168.0.1 and lose all connection!!
I am missing something big! It's a learning curve.
I doubt the ssd would be the culprit specially if it was formatted prior to use. I would lean more to the laptop/device not having latest security updates and/or the router itself having AiCloud enabled by default or forced by the malware.Of all the folks who have been impacted by this: are any of you using an SSD drive enclosure attached to the router? I was and it's the only newish device I can think of - but it didn't start right away either. Only other thing I am suspicious of is a family member's ancient laptop.
I've installed 3004.388.8_2 fresh and got diversion running again. So far no issues. Only change I've made was disconnecting the suspicious drive enclosures and using a sandisk usb stick instead. So far (~2 hours) so good. I'll wait to see if a problem arises once this laptop gets used again.
Welcome To SNBForums
