RT-AC68U Asuswrt-Merlin 386.7.2 can't access login since firmware update
Yes, computer is on 192.168.0.xx
At present, only the AC68U and another Access Point are connected wired to Fritz!Box LAN ports (AC68U WAN is connected to Fritz!Box LAN).
The AC68U Access Point is providing wireless 2.4G and 5G networks, which some devices are connected to; others are connected to 2.4G or 5G wireless networks direct from the Fritz!Box
If you connect a wired computer to one of the AC68U networking ports while that Asus router is connected to the Fritz!box can you access the Asus GUI screen?
Also, are you http://192.168.0.39/ or are you using https://192.168.0.39/ when trying to access the Asus AP? If using https then try using http instead.
Yep, that's what I've been trying. Screenshot attached.
Seems to be the same problem, the mitigation I provide here, may help you
Thanks Yota, that looked like a hopeful solution but unfortunately not. Connection being refused every time. Connection also gets refused from within Asus Device Discovery/Configure
One troubleshooting step I suppose, one could try is to see if you can access the AP using SSH. This assumes one enabled SSH when initially setting up the router into AP mode.
I hard reset again this morning to see if I could get into the GUI again, as yesterday.
No joy, it just brought up the QIS wizard... not many configuration options there, so if SSH isn't enabled by default I guess it won't be. I'd need a tutorial on how to use that anyway..! ;-)
Wondering whether setting it up as an Access Point is contributing to the issue..?
Also, wondering if there are different port options to try appending to the IP addresses (http://192.168.0.39:xxx / https://192.168.0.39:xxx)..?
It's still working as an Access Point so I have that functionality, but I've lost network storage (HDD via USB) that I was using for backup and, of course, won't be able to update firmware or do anything else 'inside' the router...
If you had a USB hard drive attached to the router you were trying to set to AP mode then having GUI access issues, remove that USB hard drive and do a hard reset of the router without the drive attached. Configure the router to AP mode, again without the drive attached then see if you can access the GUI (again without the drive attached). Assuming you haven't already been doing this.
Another troubleshooting step is to flash the stock Asus firmware to the router, set it to AP mode and see if the issue persists. Hard reset,, configure as default wifi router, flash Asus firmware, hard reset the router again, then configure as AP. In a quick test with stock Asus firmware on a RT-AC68U set to AP mode, no problem accessing the AP's GUI from either the main LAN side or from being directly connected to the AP router's networking port(s).
If you had a USB hard drive attached to the router you were trying to set to AP mode then having GUI access issues, remove that USB hard drive... Assuming you haven't already been doing this.
Yep, that's what I've been doing... removed USB before any reset and haven't reattached it.
How do I flash any firmware to the router without access to the GUI..?
I see in the manual that I could put the router into Recovery mode to do this IF the router wasn't working. But there's a warning:
"NOTE: This is not a firmware upgrade utility and cannot be used on a working Asus Wireless Router..."
Do I use Rescue mode (Firmware Restoration) as described here: https://www.asus.com/support/FAQ/1000814/
Each time you've done a hard reset of the router and been presented with the configuration page upon first GUI access have you always been choosing Access Point? If so; don't and don't connect anything else other than a single wired PC to that router. Select Wireless Router Mode instead then proceed through the rest of the quick start setup and see if you can access the GUI without having anything other than one single wired PC connected to the router. If you can then flash the stock Asus firmware from the GUI.
Otherwise yes, try the firmware restoration mode detailed at that link you provided and see if that will let you push the stock Asus firmware to the unit.
Sorry, it doesn't look like your problem is coming from the browser.
You can try this, connect the router directly to your computer with an ethernet cable, then reset it, set it to router mode in the QIS wizard, then go to Admin -- System and enable SSH.
Finally, modify it to AP mode before plugging it into your Fritz!Box.
You could try using SSH access if that works.
Thanks for your help with this, folks.
I think I've sorted it without any further resets / restoration / firmware change...
Thought I'd try accessing through a different OS... tried an old Asus Infinity tablet (Android)... no joy...
Installed Linux (FossaPupx64) on a USB flash drive, running PaleMoon browser => accessed GUI login (using http://192.168.0.39)
Changed AiCloudAccess port as you suggested a few posts back, Yota... I didn't / don't know the numbers of available / valid ports so I just took a guess and set it to 993 (I'm not using AiCloud so it maybe doesn't matter whether it works..?!)
Bingo! I can now login to the GUI from the tablet, phone and Windows using http://192.168.0.39/
Still rejects https://192.168.0.39/
And have the USB HDD NAS running and accepting file copying
Thanks again,
Ian
I'm still puzzled by this. Was it a browser problem then? It doesn't make sense to me that the problem was the operating system of the client.
