RT-AC68U Build 380.69 VPN Client Issue
CO_Chewie
Hello,
I was wondering if anyone else has run into issues with the VPN Client page (Advanced_OpenVPNClient_Content.asp) whereas after setting the Redirect Internet Traffic to Policy and a applying a routing rule the page breaks? I loose the header and sidebar and all buttons don't respond:
The only way this can be remedied that I can find, is to preform a factor reset. I have tried twice to set this up and the second time I made sure to set the rules before enabling the VPN (service state to on). I am trying to excluded a particular IP from using the VPN but it seems that using a routing rule is breaking the functionality.
Are you using any special characters in the Description field (i.e. John's PC is a not good with the single quote). Stick with alpha-numerics, dash and underscore (good advice for any names or passwords to avoid problems).
