After recently purchasing my RT-AC68U it's been working great, aside from one very frustrating issue.
I have a 50Mb fiber connection to my home, which includes Fioptics cable. If I connect my gaming PC directly to the cable modem with a wired connection I consistently get ~28Mb/s after cable overhead is accounted for, which is perfectly acceptable.
If I connect Modem -> RT-AC68U -> Netgear Switch -> (different)PC I get the same results at ~28Mb/s.
However, if I connect my gaming PC to the RT-AC68U my speeds are never more than ~12Mb/s, which is less than half the available bandwidth. YouTube videos are constantly buffering as well, which shouldn't be an issue with even a 12Mb/s connection.
I'm running the latest Merlin build with factory default settings.
Wireless connection is working with great speeds.
Another wired connection running through a switch is getting 28Mb/s.
Wired connection directly from cable modem to gaming PC gets 28Mb/s.
Wired connection to gaming PC running through RT-AC68U using same ethernet cable is limited to 12Mb/s.
I spent hours scouring forums trying to find a solution last night, but nothing seems to be working and I need help!
Does anyone know what might be the cause of this?
