RT-AC68U New FW
I've just updated to 3.0.0.4.378_4585, and there is a problem with the guest wifi. I have had a guest 2.4 wifi on my RT-AC68U (wpa2 personal, without intranet access and without mac filtering). After the update, the guest wifi turned out(?) somehow to an enabled mac filtering one, and I can not turn this feature off. After I choose the "No" option and save the form, nothing happens. It looks like, the router saves the configuration (the percentage counts as normally up to 100%). I can rename the guest wifi or change the pw or the intranet setting, but can not disable the mac filtering. What should I do?
I can even delete that guest wifi, and start a new one (tried to start one in the 2nd block), but the mac filtering is always enabled :(
Updated to the latest available fw (378.52_2) and everything seems right. I can switch between mac filtering option.
