RT-AC68U Slow USB 3.0 speeds
I am sorry I did not respond to this earlier. I am not a dedicated representative on this forum, so I do not consistently read or respond to all the postings here. We will have someone representing this forum on a more consistent basis soon.
There is a possibility of interference, but it is more likely to come from the USB 3.0 cable on the USB drive, not the router. From testing, a USB 3.0 cable with poor braiding and foil can cause interference. You can read more about the issue from Intel's documentation. Refer to section 3.1:
http://www.intel.com/content/dam/ww...-papers/usb3-frequency-interference-paper.pdf
The RT-AC68U does have shielding. It is a large shield around the antenna connectors (See picture below). This should protect against interference better than a small shield around the USB 3.0 port.
The USB 3.0 circuits are also embedded into the multi-layer PCB of the RT-AC68U, which will also help mitigate the possibility of interference.
thank you, this made me feel better about my investment, i would assume the problem is the firmware right now right? which shouldn't be a problem when you release better firmware.
So I purchased the ac68u today, set it up and its working so much better than my returned ea6500.
but I seem to be having an issue with the usb/Hdd I plug into the router,
I am not able to write or delete files on the shared drive. ive tired all options but nothing and I cant find any info on it.
My firmware is 3.0.0.4.374_205
updated to 291 but still cannot add or delete files on the usb shared drive. any clues on how to solve this?
If this is formatted in ext2/ext3 make sure your file permissions actually allow any user to write to the disk.
If it's FAT32, keep in mind you cannot write files larger than 4 GB with that filesystem.
Otherwise, double check permissions on the sharing configuration page to ensure you do allocate write access.
so, I formatted the flash drive (4 gigs) to ext3, plugged it into the router and everything disconnected from it, all wireless networks disappeared , lost internet connection.. waited a few, restarted, nothing. unplugged the usb disk and everything went back to normal.
Your post never mentioned anything about losing Internet access, you were talking about being unable to write to the disk. If you are using ext3 then it means your filesystem permissions are wrong. chmod the disk and its filesystem to 777.
If everything goes down for a minute or two, then it means your router has just rebooted. That has nothing to do with writing issues however and is a different problem. You might want to do a fsck on that disk to ensure it's not corrupted.
I only lose internet access and all networks disappear if the usb drive is formatted at ext 3, its not a reboot, the router actually goes dead silent.
If the format is fat32 or ntsf,the router functions fine and I can read the data and stream it to my devices but I cannot paste a video file to delete files etc. ive tried the share , share with contact, ftp etc nothing seems to allow me to write/modify the usd drive.
my hard drive doesn't work at all at USB 3.0 speed, it tries to make it work but with no luck;
both wifi's (2,4 GHz and 5 GHz) were switched off;
after every FW flash I did hard reset with nvram clear (holding power + wps buttons for 10 seconds);
this what I get in logs with the latest Merlin's FW
RT-AC68U_3.0.0.4_374.34_2:
Jan  1 00:02:40 rc_service: radio 593:notify_rc restart_wireless
Jan  1 00:02:44 kernel: device eth1 left promiscuous mode
Jan  1 00:02:44 kernel: br0: port 2(eth1) entering forwarding state
Jan  1 00:02:44 kernel: device eth2 left promiscuous mode
Jan  1 00:02:44 kernel: br0: port 3(eth2) entering forwarding state
Jan  1 00:02:44 dnsmasq-dhcp[484]: DHCPINFORM(br0) 192.168.1.134 00:23:54:9c:03:de
Jan  1 00:02:44 dnsmasq-dhcp[484]: DHCPACK(br0) 192.168.1.134 00:23:54:9c:03:de DVD
Jan  1 00:02:48 kernel: wl_module_init: passivemode set to 0x0
Jan  1 00:02:48 kernel: wl_module_init: txworkq set to 0x1
Jan  1 00:02:48 kernel: eth1: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.34 (r415984)
Jan  1 00:02:48 kernel: eth2: Broadcom BCM4360 802.11 Wireless Controller 6.37.14.34 (r415984)
Jan  1 00:02:48 kernel: device eth1 entered promiscuous mode
Jan  1 00:02:48 kernel: br0: topology change detected, propagating
Jan  1 00:02:48 kernel: br0: port 2(eth1) entering forwarding state
Jan  1 00:02:48 kernel: device eth2 entered promiscuous mode
Jan  1 00:02:48 kernel: br0: port 3(eth2) entering forwarding state
Jan  1 00:03:17 kernel: hub 2-0:1.0: unable to enumerate USB device on port 1
Jan  1 00:03:18 kernel: usb 1-1: new SuperSpeed USB device using xhci_hcd and address 2
Jan  1 00:03:18 kernel: xhci_hcd 0000:00:0b.0: WARN: short transfer on control ep
Jan  1 00:03:18 kernel: force burst = 0.
Jan  1 00:03:18 kernel: xhci_hcd 0000:00:0b.0: WARN no SS endpoint bMaxBurst
Jan  1 00:03:18 kernel: scsi0 : usb-storage 1-1:1.0
Jan  1 00:03:20 kernel: scsi 0:0:0:0: Direct-Access     SAMSUNG  HD103SJ          0000 PQ: 0 ANSI: 2 CCS
Jan  1 00:03:20 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan  1 00:03:20 kernel: sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
Jan  1 00:03:20 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
Jan  1 00:03:20 kernel: sd 0:0:0:0: [sda] Write Protect is off
Jan  1 00:03:20 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jan  1 00:03:20 kernel:  sda: sda1
Jan  1 00:03:20 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jan  1 00:03:20 hotplug[684]: USB /dev/sda1(ntfs) failed to mount at the first try!
Jan  1 00:03:20 kernel: ufsd: use builtin utf8 instead of kernel utf8
Jan  1 00:03:20 kernel: xhci_hcd 0000:00:0b.0: WARN: transfer error on endpoint
Jan  1 00:03:20 kernel: usb 1-1: USB disconnect, address 2
Jan  1 00:03:20 kernel: sd 0:0:0:0: [sda] Unhandled error code
Jan  1 00:03:20 kernel: sd 0:0:0:0: [sda]  Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
Jan  1 00:03:20 kernel: sd 0:0:0:0: [sda] CDB: Read(10): 28 00 00 58 c2 aa 00 00 40 00
Jan  1 00:03:20 kernel: end_request: I/O error, dev sda, sector 5817002
Jan  1 00:03:20 rc_service: hotplug 730:notify_rc restart_nasapps
Jan  1 00:03:20 rc_service: hotplug 743:notify_rc restart_nasapps
Jan  1 00:03:20 rc_service: restart_nasapps is waitting restart_nasapps...
Jan  1 00:03:20 FTP Server: daemon is stoped
Jan  1 00:03:21 Samba Server: smb daemon is stoped
Jan  1 00:03:21 kernel: gro disabled
Jan  1 00:03:22 FTP Server: daemon is stoped
Jan  1 00:03:23 Samba Server: smb daemon is stoped
Jan  1 00:03:23 kernel: gro disabled
and this with latest Asus FW FW_RT_AC68U_3004374339:
Nov  7 01:02:24 kernel: xhci_hcd 0000:00:0b.0: WARN: short transfer on control ep
Nov  7 01:02:24 kernel: force burst = 0.
Nov  7 01:02:24 kernel: xhci_hcd 0000:00:0b.0: WARN no SS endpoint bMaxBurst
Nov  7 01:02:24 WEBDAV server: daemon is started
Nov  7 01:02:25 kernel: scsi 2:0:0:0: Direct-Access     SAMSUNG  HD103SJ          0000 PQ: 0 ANSI: 2 CCS
Nov  7 01:02:25 kernel: sd 2:0:0:0: Attached scsi generic sg0 type 0
Nov  7 01:02:25 kernel: sd 2:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
Nov  7 01:02:25 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
Nov  7 01:02:25 kernel: sd 2:0:0:0: [sda] Write Protect is off
Nov  7 01:02:25 kernel: sd 2:0:0:0: [sda] Assuming drive cache: write through
Nov  7 01:02:25 kernel: sd 2:0:0:0: [sda] Attached SCSI disk
Nov  7 01:02:26 kernel: xhci_hcd 0000:00:0b.0: WARN: transfer error on endpoint
Nov  7 01:02:26 kernel: end_request: I/O error, dev sda, sector 5816618
Nov  7 01:02:26 kernel: ufsd:BdRead: failed to map block starting from 58b92a, 74705800
Nov  7 01:02:26 kernel: ufsd:BdRead: failed to map block starting from 2, 74705800
Nov  7 01:02:28 rc_service: hotplug 867:notify_rc restart_nasapps
Nov  7 01:02:28 rc_service: hotplug 868:notify_rc restart_nasapps
Nov  7 01:02:28 rc_service: waitting "restart_nasapps" via  ...
Nov  7 01:02:28 FTP Server: daemon is stoped
Nov  7 01:02:28 Samba Server: smb daemon is stoped
I see a lot of transfer errors in your log. This is usually a problem with the USB cable or the disk itself.
You could try running a disk check from a PC, but I suspect the issue is more hardware than software.
Hmm,
If indeed it were hw problem, might be ultimately ASUS ought to come out with AC68U Rev. 1? Some hw issues can be masked or made to go around the problem by f/w but in certain cases hw mod. is the only remedy.
I have no problems with USB 2.0, so is it possible?
Sure, if your cable is not up to specs, and having troubles dealing with the higher data rate negotiated by the USB3 port.
I had same experience with ext3 partition on RT-AC56U, here is my post (I have no solution for this, but I'm sure it's not disk, or formating problem, because I tried more disk and these disk work well on AC66U):
http://forums.smallnetbuilder.com/showpost.php?p=83583&postcount=194
You were right, there was an issue with USB cable, tnx
so I purchased a usb 3.0 HDD, and on my laptop I get 120MB/s read write (checked with crystal disk mark) but when I plug it into the routers 3.0 slot, I am only getting 22MB/s max speed, and yes I have turned off the 3.0 interference option.
on what FW ? on latest 371 or Merlin's you should able to get 30-50MB (from what I've read on forum)
You'll never get close to 120 MB/s on a router that has a 800 MHz CPU and 256 MB of RAM.
on firmware 371, on my wired pc it goes to 31MB/s, my laptop is on ac, 866MB/s speed, full bars, why does it only max at 22.
Also, I had my acronis image my system to the drive connected to the router, and it started going well, writing at 22MB/s, then after 10m it drops to 400kb and disconnects.
