I just sorted this firmware like 4-5 days ago..
Firmware:3.0.0.4.374.37 (Merlin build)
Think it should be the latest.
It isn't. 374.37 was known to have wireless issues on the AC56/AC68, reported on the dedicated thread for that release.
thanks,
ALso I wonder what happens in the following cases when using the merlin firmware on a asus RT-AC68U router:
If using OpenVPN client on the router, and the VPN goes down, either just for a few seconds or for say an hour. Will my regular internet kick in then and reveal my real IP or will I simply be without internet until the VPN is back online?
Also is there somewhere I can see the log of this VPN connetion activity?
cheers
our broadband uses ADSL technology and it needs a modem. I have a belkin router with in built modem at the moment. This router is not good for online gaming. i am planning to disable the wireless capabilities of this router and use ac68u as router.
what i need to know is how this router behaves in this case. will i get all the benefits of ac68u
I have Asus RT-AC68U, firmware RT-AC68U_3.0.0.4_374.38_2 (Merlin - build) and internet 1000 Mbps in WAN.
It is normal to have CPU - 91 ° C?
thank you
374.38_2 is based on the source code of Asus's 374_583, so it has the same level of functionality.
There is no need to upgrade the bootloader if you are already on 1.0.1.6.
Ah ok. I was just confused because the read me states:
"based on RT-N66U 3.0.0.4.374_2078 sources (unreleased) from Asus"
With no mention of Asus's 374_583
Thank you!
Welcome To SNBForums
