RT-AC68W with FW_RT_AC68W_300438410007 - No AIMesh in GUI?!
I have the same exact problem with my RT-AC68A for Amazon.
The quick set up references it but the button is missing.
there is new firmware available 384.20287, if you dont see it under windows 10, try search under OS.
it takes while for it to populate under other category
Asus also now has a new "Firmware" option on the left side of the product support page.
I can confirm that the latest version fixed all my issues. The RT-AC68W is now up and running as a Mesh-node.
Thank you very much @arthurlien for the support!
I have the problem after upgraded to latest AC-68U firmware launch few days ago, one of AiMesh node is gone and even Hard rest. it has the same problem of AiMesh menu gone. The one works perfectly with RT-AC5300 before upgrade just hand occasionally. Anyone Can help?
