RT-AC86U - 3.0.0.4.384.20467
Stateful IPV6 does not work. When the router is configured for Stateful IPV6 and a reboot is run, the post reboot IPV6 tab shows a LAN IPV6 Address and a LAN IPV6 Prefix. If you run an ipconfig/all to check the connected pc IP address, you will see that the device does not have an IPV6 address. This was the same situation for Firmware Version 3.0.0.4.384.20308. When Stateless IPV6 is selected, the IPV6 tab shows the same LAN IPV6 Address and LAN IPV6 Prefix and the connected pc has an IPV6 address.
Still getting repeating system log message on 86U (main router) latest 20467 firmware:
Mar 18 15:45:25 Mastiff: Got SIGABRT
Mar 18 15:45:51 rc_service: watchdog 807:notify_rc stop_aae
Mar 18 15:45:51 rc_service: watchdog 807:notify_rc start_mastiff
Mar 18 15:45:51 rc_service: waitting "stop_aae" via watchdog ...
Mar 18 15:45:51 NAT Tunnel: AAE Service is stopped
Mar 18 15:45:52 NAT Tunnel: AAE Service is stopped
Mar 18 15:45:52 AAE: AAE Service is started
Mar 18 15:45:52 Mastiff: init
Mar 18 15:46:26 Mastiff: Got SIGABRT
Mar 18 15:46:51 rc_service: watchdog 807:notify_rc stop_aae
Mar 18 15:46:51 rc_service: watchdog 807:notify_rc start_mastiff
Mar 18 15:46:51 rc_service: waitting "stop_aae" via watchdog ...
Mar 18 15:46:51 NAT Tunnel: AAE Service is stopped
Mar 18 15:46:52 NAT Tunnel: AAE Service is stopped
Mar 18 15:46:52 AAE: AAE Service is started
Mar 18 15:46:52 Mastiff: init
Using RT-AC68R as node (on 20308 firmware)
Some possible firmware defects:
o DST settings do not stick (I believe this is a known JAVA script issue to be fixed in the next release).
o Firewall/URL Filter/black listing does not seem to work. I did not try white listing.
OE
use feedback function to asus from router gui.
ASUS RT-AC86U Firmware version 3.0.0.4.384.20648
Suport multi-langue(UTF-8) network name*
Security fixed
-Fixed CVE-2018-8826 remote code execution vulnerability. Thanks to Chris Wood.
Bug fixed
- Improved AiMesh stability.
- Fixed AiMesh mac filter bugs
- Improved system stability.
- Fixed DST related bugs.
- Fixed client list related bugs.
- Fixed traffic analyzer UI bugs.
OE
I'm installing 384.20648 now but want to mention that Roaming Assistant stops working after a while with 384.20467. I reported it to ASUS, and hopefully the issue will be fixed in 20648.
