I need some help with a quite annoying problem I have using VPN on my Merlin flashed router.
When I start torrenting over VPN, my whole internet connection crashes (not just the VPN tunnel) and my modem needs to recycle and re-acquire an IP from my ISP every couple of minutes. The crash varies in frequency between 5 and 10 minutes without any pattern. This only happens when torrenting, normal internet traffic through the VPN can go for days without interruption.
My setup:
ISP > own modem in Bridge mode > RT-AC86U Merlin (384.6) > home network
I'm in Australia where internet is still pre-historic with a PPPoe ADSL2+ connection and I achieve max speeds of 1.4Mbs, so the router cannot be overloaded.
My home network consists of 2 laptops, Apple TV, HomePod and a Synology NAS. This should also be more than ok for the router to handle.
The problem occurs both when torrenting on the NAS and from laptop (with NAS disonnected from network).
What I already tested:
- used another modem -> same problem
- changed VPN provider (Expressvpn & VPNarea) -> same problem
- activated VPN tunnel directly on NAS instead of router -> same problem
- ISP checked the line, noise, node -> no change
- original ASUS firmware on router -> same problem
The only setup were I have no crash of internet is having VPN on my laptop and torrenting from my latpop with utorrent. When I use Transmission, the connection also crashes.
It's driving me nuts. What can be the cause?
Thanks for your help guys (&gals)!
My setup:
