ColinTaylor
Part of the Furniture
Yes, EU is a region. AFAIK Asus doesn't differentiate between countries within the EU.How does Asus define those regions?
Is Europe a region, or should I even check for specific countries within it?
Hello,Here how it looks like. I am on latest beta build with AiMesh functionality
Hello,
which firmware are you using correctly? I bought my AC86U in germany and the region dropdown is completely missing with firmware 3.0.0.4.382.16466
Probably only the chinese model got that dropdown.
Is the "region" dropdown still available with merlin's custom firmware?yes it's the Chinese model that got that
It would be really nice if you could test if the "region dropdown" is available with the latest Asuswrt Merlin.not sure I'll need to wait for my order to get here from china to test. I just ordered it on Oct 2nd, item tracking status says it's now packed and ready to ship by DHL
Test builds are available here (all credits go to merlin): https://www.mediafire.com/folder/bj94sbhrh7e49/Test_Builds
Since it's not possible to adjust the TX power anymore, does changing the region automatically adjust the transmit power?
EU would work with 20 dBm (100 mW) and US with 23 dBm (200 mW), is that possible?
Thanks merlin.It's not a question of firmware, it's a question of region. The firmware will only display the dropdown for some models within some specific regions. For instance, the region selector will not appear for routers set for the US region.
The behaviour of my firmware is 100% identical to that of the stock firmware there.
Can you tell us if changing the region affects the used transmit power?
As Merlin mentioned it's doesn't matter what FW is loaded it'll still have the region select drop down menu, that is as long as Asus doesn't change this in the boot loader.
So you have it set to english how does that give you the extra channels ? How did you change the region ?
Welcome To SNBForums
