[RT-AC86U] I built cake!!!
I simply uninstalled freshqos when I disabled Adaptive QoS as a precaution.
So did i, but for some reason i still had it running in firewall-start
can't install: bin.entware.net still down...
Latest install script and attachment to firewall-start seems to be working perfectly.
I uninstalled the lot, and ran the new install procedure. All new script in place and applied properly.
I then ran a firmware update from 384.17 to 384.18b1 and restarted. Cake all active and operating perfectly without further intervention.
Thank you, it was a smooth upgrade to v0.0.2 on my AX88U running 384.18_beta1.
I installed Cake after lurking for a while on this thread and everything went without a hitch. I did some testing and it works as expected. Especially important for this router is VoIP which seems to work very well and best of all I didn't have to do any manual adjustments to get it to work without any stuttering. It really is an install and forget solution.
