Hi guys, long-time lurker, first-time poster.
For the last two months, I've been getting intermittent issues with websites not loading and getting stuck on DNS_PROBE_FINISHED_NXDOMAIN.
A manual reload of the website or waiting for chrome to auto-refresh causes the page to load.
This issue is observed on all devices under the router.
Setup: RT-AC86U with Merlin's 386.2_2 + Raspbi Pi4 (Pihole+Unbound+Media Server)
Raspberry Pi's IP is entered on WAN DNS, LAN DNS under DHCP, and DHCP filter is set to the Raspbi's IP for pihole and unbound to work. (Raspbi Pi was given a no filtering option)
Unbound is set up as a caching forwarder for DNS over TLS to Cloudflare.
All 4 ports and 2 USBs are populated on the router. One USB for scripts and the other for file sharing.
The setup was working without any errors for the past year.
The unbound config from Martineau's script was used with some device-specific modifications.
There are no specific logs when the issue happens on the router.
I've tried L&LD's nuclear reset and tried with 3 different versions of merlin.
Even a reset to the stock firmware with minimal config caused the issue to persist. (Using automatic WAN DNS and Ai Protection off)
The temperature on the CPU is hovering around 80C with a router-mounted fan in a room with a 35C ambient temp. (No thermal throttle on the logs)
Any idea on what could be causing these intermittent failures?
Please let me know if any additional information is needed.
