RT-AC86U IPV6 Router Advertisement not working properly
Hi @L&LD
Actually I've done just "normal" resets.
I tried latest 386.1b4b and rolled back again to 384.19 due to usual Temp issue.
This IPv6 issue seems to be quite persistent between different releases.
I've checked many times, I'm starting to think that cannot be just a coincidence that on iPhone (bsd based) the problem doesn't appear.
As soon as I'll receive the next update to Android 11 I'll check once more.
Anybody knows what to look at / which terminal commands should I do in order to check what's happening?
When it happens, I've found it can be solved by disabling ipv6 entirely, then going back to 6in4 (or whatever you had)
This is still completely unreliable. Practically every time I reboot my router I have to disable and then enable the Router Advertisement option. Is this a bug in asus code or...?
Adding an update: it's clearly a problem in Asus code because it happens with the stock firmware also.
