Im with the same problem as you. Wifi getting 240Mbps and using cable 96Mbps.Firmware: 384.14_2
Model: RT-AC86U
Issues:
LAN speed is limit at 200mbps, but my WiFi speed can go up to 100% at 500mbps.
There's no NAT Acceleration setting, but HW acceleration shows:
Runner: Enabled - Flow Cache: Enabled
QoS Settings:
QoS Type: **Adaptive**
Queue Discipline: **sfq**
LAN-Switch Control:
Jumbo Frame: **Disable**
Spanning Tree Protocol: **Disable**
I`ve printed the status page and found this:
But I haven't found the right place to switch Lan ports to Gigabit.
