Which firmware is this please? The one in the title of this thread or a different one? Thank you.84 days uptime on this firmware...rock solid.
I'm getting a used 86U after a long time of waiting and on the verge of deciding between the most stable official (if I can find what that firmware is) or go Merlin but I'm not very techy so a little scared of third party firmware.
OE,
OE,
I thought Asus redirects AiMesh Node GUI to Main AiMesh Router (?), looks like a bug, I tried to play with a few other pages, they get redirected to AiMesh Router.
Can someone help before I toss this router out the window ACu86 keeps dropping my 2.4ghz connection. I see it appear and then disappear and when its there it says internet not available. So what can I do as I have some hardware that requires 2.4 as they wont connect to 5.0 wifi.
Made in China 2018 and settings you mentioned did not work.Works here.
If all 2.4 clients exhibit the same issue, then confirm the router firmware is commissioned properly, starting with a fresh firmware download and install, reset and configuration... see 2.4 settings suggested in my install notes. Try a different channel in case there is some strong interference on the channel being used now. Also, disable USB 3.0 mode on the router... if used, it can disrupt 2.4 clients.
If the 2.4 signal remains abnormal (watch it with a WiFi Analyzer) and not reliable for different 2.4 clients, then the AC86U hardware/2.4 radio may be failing. Is there a country and date of manufacture on the rear label?
And assume you will figure this out or else you won't have the troubleshooting will to get it done.
OE
what did you replace it with?The AC86U has an early reputation for hardware failure... 2.4 radio and a VR chip burning up. I had two China 2018 builds fail, one in and one out of warranty. I'd say your 86U is failing and would plan to replace it.
OE
Yes I have my old router Archer c7 may have to do that. Now can you walk me through AP mode so I can get it to work along side of my AC86u. I have my Rogers modem bridged to my AC86u router ATM.Another AC86U, Vietnam 2020 (same as the warranty replacement).
Since then, the RT-AX86U has become a candidate but prices are up, supply is down, and WiFi6e is still emerging, so it's a calculated decision. You may have to make a move, so you might want to review the current AX variants similar to the AX86U and see what others think about their AX choice. I'm still holding with my AC routers.
Maybe you could buy some time with an old router... wire it up in AP mode to serve your 2.4 clients (turn OFF the 2.4 radio in the AC86U).
OE
Disable the 2.4 radio in the AC86U webUI.
Then setup the Archer C7 in AP Mode and wire it to a LAN port on the AC86U. Once you login and set the C7 for AP Mode, the wireless settings should be straightforward... I would disable the 5.0 radio to not conflict with the AC86U 5.0 WLA
Hi what port should I plug in the wire at the back of the c7 Lan or the main port?Disable the 2.4 radio in the AC86U webUI.
Then setup the Archer C7 in AP Mode and wire it to a LAN port on the AC86U. Once you login and set the C7 for AP Mode, the wireless settings should be straightforward... I would disable the 5.0 radio to not conflict with the AC86U 5.0 WLAN(s) (if possible?).
OE
Welcome To SNBForums
