I doubt it works, but still lets wait for his confirmation.Does the LAN port #1 still work?
The Quantenna OS does not boot for some reason, no way to login to the OS, and nothing related with Quantenna FW (qcsapi) works.
This seems a obvious Quantenna HW failure to me, i could see what was going on easily via serial console, but i will not since is still on warranty period.
On AC87U/R when the 5GHZ radio was disabled the temperature status was still there, the Quantenna system was never "offline", and now the status page shows it as DISABLED.
My CFE was the original one / not touched so i cannot tell about it.
What have you modified on it? What issue you are refeering to? 5GHZ band not working (showing as DISABLED)? LAN1? Both?
Maybe you have corrupted some value on the 5GHZ band.
Not sure if this is a HW failure, or that the QTN firmware/boot configs have gotten corrupted - it may be sitting in the bootloader waiting for interaction on the shell/monitor...
Like i mention before i didnt want to connect the serial cable because of warranty, but if they got corrupted like you said its even a worse scenario, i have seen this exact situation happening on untouched CFE with stock ASUS FW, so...
5GHZ LED turned off, LAN1 not working, 5GHZ status DISABLED (this one was confirmed after flashing RMerlin FW)
Ps, this router becomes sluggish has crashed several times when my laptop cooler is off.
the AC87U is an odd architecture..
Sorry the delay answering, alot going on lately, yes Netgear QTN GPL version is a recent version than ASUS, its v37.3.1.25.
Welcome To SNBForums
