RT-AC87U AiProtection
Does AIProtection slow down throughput? Would a solution like CUJO be better?
From the tests I did with a 250 mbit/s link, there was no visible bandwidth or CPU usage difference.
I used to work for a DPI company and typically the protocol matching is done with the first few packets of a connection. It should only be of concern if you run a server which is being heavily hammered by incoming connections.
The main problem with AiProtection is that it has no whitelisting system and can prevent perfectly reasonables protocols (like a bitcoin wallet) from working.
AIProtection itself doesn't slow down throughput. If you don't care about Traffic Analyzer's Statistics, then AiProtection with all HW acceleration enabled, should reach over 900++Mbps. But if you disable on of the HW accelerations to get correct statistics, you should get around 250-300Mbps on Asus AC68U. AC87U should do a little better, but not by much.
