RT-AC87U current status with wifi issues?
@bones5050 exactly....Another post is not related to the topic , and you say that I am hijacker ?
The summit of hypocrisy .
Just take it easy pal, let's all be friends. We have enough War in this planet. Don't need to make War here.
Chrisnasah got the answer he wanted and that's the most important :)
And if you don't like my posts, then you may contact an moderator and ask him/her to delete my posts.
Many people seem to have issues with 5ghz but that works great for me. I "think" my problems are with 2.4Ghz. With the latest stock firmware it seemed worse (2-3 days and it completely locks up, even the lan connections). Using Merlin's latest release, (6-8 days before complete lockup).
Most of my usage is on the 2.4ghz side with 4-6 devices connected at all times. On 5ghz there are only 2 devices and they are mostly turned off or in sleep mode.
Currently I have 2.4ghz disabled and I'm using an RT-N16 with hggomes firmware hooked up as an AP for 2.4Ghz. Hopefully this will shed some light on where my problem is. My up time was 5 days but recently i noticed that it rebooted itself 17 hours ago. The last entry in the log before it rebooted had to do with my wireless canon printer that uses 2.4ghz.
I'm still trying to wrap my head around this problem.
EDIT: After more testing it does seem to be the 5ghz Quantenna radio. I'm starting to think they cant fix this thing with updates.
i dont have wifi issue(?) with ac87u and android/ios/osx/win devices. if you have a problem with apple devices, you could try to disable beamforming from ac87u.
Sent from my iPad Air 2 using Tapatalk
M RT-AC87U & OpenVPN: Using insecure hash algorithm in CA Sig ASUS Wi-Fi 11
