[RT-AC87U] "The requested URL was rejected"
turbocycle
Looking for help on an interesting problem I encountered yesterday:
When I try try to access the website "amctheatres.com" from any device connected to my ASUS RT-AC87U, I am getting the following error:
The requested URL was rejected. Please consult with your administrator.
Your support ID is: xxxxxxxxxxxxxxxxxxxx
If I connect my PC directly to the cable modem, I can access the site and don't get any error.
I can access all other websites that I tried while connected to the router except amctheatres.com
Traceroute looks different from router compared to direct coneection. Could this be a clue? See below for traceroute outputs.
Something about the router seems to be affecting the error. Has anyone heard of this problem?
More details below:
Router has latest firmware version: (3.0.0.4.382_50010)
Router has been factory initialized
ISP is xfinity
Failure affects any device (laptop, phone, tablet) connected to Router
Setting in the router that I've tried to enable/disable:
Disabled AIProtection and parental controls
Disabled firewall & DDOS protection
Changed DNS (I've tried quad9)
Enabling and disabling IPv6
Other things I've tried:
Clear cookies and cache in Google Chrome on PC and phone
Tried different web browsers (Google Chrome; Microsoft Edge)
Traceroute:
traceroute to the site looks different when I connect directly compared to when I use the router.
Traceroute using cable modem direct connection: (connects to site)
Tracing route to amctheatres.com [169.224.240.210]
over a maximum of 30 hops:
1 8 ms 8 ms 7 ms 96.120.91.193
2 8 ms 7 ms 8 ms be-20021-rur02.sanjose.ca.sfba.comcast.net [68.87.198.177]
3 9 ms 9 ms 10 ms be-331-ar01.hayward.ca.sfba.comcast.net [162.151.79.153]
4 14 ms 10 ms 12 ms be-3651-cr01.9greatoaks.ca.ibone.comcast.net [68.86.91.65]
5 11 ms 11 ms 11 ms hu-0-16-0-1-pe03.11greatoaks.ca.ibone.comcast.net [68.86.88.6]
6 16 ms 15 ms 15 ms 192.205.32.213
7 56 ms 55 ms 55 ms cr2.sffca.ip.att.net [12.122.149.134]
8 61 ms 55 ms 64 ms 12.122.28.117
9 70 ms 57 ms 55 ms cr1.kc9mo.ip.att.net [12.122.3.46]
10 55 ms 54 ms 57 ms 12.122.150.9
11 55 ms 54 ms 55 ms 12.252.221.62
12 62 ms 61 ms 62 ms rtr-lx-1n1.arsalon.net [204.13.97.1]
13 62 ms 62 ms 64 ms 204-13-97-250.arsalon.net [204.13.97.250]
14 68 ms 61 ms 61 ms 169.224.240.210
Trace complete.
Traceroute using router (Request Rejected error):
1 <1 ms <1 ms <1 ms router.asus.com [192.168.1.1]
2 14 ms 8 ms 10 ms 96.120.91.193
3 9 ms 7 ms 7 ms be-10021-rur01.sanjose.ca.sfba.comcast.net [68.87.198.169]
4 8 ms 7 ms 7 ms be-231-ar01.santaclara.ca.sfba.comcast.net [162.151.78.249]
5 9 ms 10 ms 10 ms be-3651-cr02.sunnyvale.ca.ibone.comcast.net [68.86.91.73]
6 8 ms 8 ms 9 ms be-11083-pe02.529bryant.ca.ibone.comcast.net [68.86.84.14]
7 32 ms 28 ms 28 ms 50.248.118.238
8 28 ms 30 ms 28 ms be2015.ccr21.sfo01.atlas.cogentco.com [154.54.7.173]
9 39 ms 35 ms 34 ms be3109.ccr21.slc01.atlas.cogentco.com [154.54.44.138]
10 34 ms 34 ms 35 ms be3038.ccr22.den01.atlas.cogentco.com [154.54.42.98]
11 56 ms 52 ms 51 ms be3036.ccr22.mci01.atlas.cogentco.com [154.54.31.90]
12 51 ms 52 ms 52 ms te0-0-2-3.agr12.mci01.atlas.cogentco.com [154.54.27.126]
13 52 ms 52 ms 52 ms 154.24.56.222
14 51 ms 52 ms 52 ms 38.104.88.70
15 51 ms 53 ms 52 ms rtr-pr-1o1.arsalon.net [208.89.116.5]
16 58 ms 58 ms 58 ms rtr-lx-1n1.arsalon.net [204.13.97.1]
17 63 ms 58 ms 59 ms 204-13-97-250.arsalon.net [204.13.97.250]
18 60 ms 60 ms 59 ms 169.224.240.210
It's not your router, it's most likely the IP address your ISP gives you then, which is blacklisted by the remote site.
Thanks for the reply! I can access the site now. I always knew it wasn't the router causing the problem directly, but it's a good lesson that sometimes what appears to be the problem may not necessarily be the root cause of a network problem.
