RT-AC87U USB-drive problem
AlexeyY
Good day!...
Problem: If I use a usb-disk (use samba or ftp, fat32 or ext - no difference) in LAN, when copying large files, speed drops after some time, the CPU usage grows and in the end, copying interrupted (no disk access). On native firmware I dont have this problem. Sincerely, Alex
Firmware: 380.66_4
Probably why it crashes. May not be the best solution but look into turning a USB drive into swap
The impression that the swap fills up after some time... but to go to terminal again, look for what's i can tune with the realy ability to get brick from router... If the original firmware everything works... I dont see for what
But thanks
Forgot to say - as a router (wan-lan) continues to work without problems (only in control panel not to go sometimes)
