Comment #15 says that MU-MIMO is seen as enabled in the beacon VTH Capabilities.MU-MIMO isn't enabled in this build.
Exactly, that's why i was asking for...Comment #15 says that MU-MIMO is seen as enabled in the beacon VTH Capabilities.
So does anyone actually know if MU-MIMO is enabled or not?
Build 6440 & 6687 MU-MIMO isn't enable.Exactly, that's why i was asking for...
Why on earth are there so many different experiences with this, I understand people have different environments but are there different hw revisions around or something?
I am really considering purchasing this as my next router as I need something with more cpu.
That is exactly what I keep on asking myself, I tend to have more problems than most, I also have set up one of these for a friend that lives ~5 miles from me, they have the same issues with firmware as I do, so my conclusion is others are on other wifi networks and don't know it, that actually work, or others found something in this firmware to tweak and are not saying.Why on earth are there so many different experiences with this, I understand people have different environments but are there different hw revisions around or something?
try with similar settings as the ones in the attached screenshots, if those can be applied in your case.or others found something in this firmware to tweak and are not saying.
I usually leave all wifi settings to factory defaults, and I don't get it.
RT-AC87U_3.0.0.4_378_6687 - Unofficial beta firmware
Download: https://goo.gl/qGUiRy
Improvement:
Update 5Ghz SDK
Improve 5Ghz
Require: Hard reset
I was wondering the same thingRegarding a Hard Reset. Will the command 'mtd-erase2 nvram' accomplish this task?
Yes, just power cycle it after running the command.Regarding a Hard Reset. Will the command 'mtd-erase2 nvram' accomplish this task?
For people who were complaining about a 2ms delay when using the 5GHz network: Are you still getting that issue with this beta firmware?
Also anybody who had problems with Beamforming (5GHz, as always): Still having those problems with this release?
Welcome To SNBForums
