Good morning all,
I've setup my RT-AC88U, and part of that required me to do the following
I recall with my RT-AC66U that I had to run the following commands to enable LAN 3 and LAN 4 ports:
reboot
Do I still need to issue those commands to ensure LAN 3 and LAN 4 are enabled? Is there a command I can run to see before running the above what the status of the ports are? I'd guess it would just be LAN 3 and LAN 4 that are disabled, and LAN 5 through 8 would work as normal?
thanks in advance for any help.
- Go into LAN -> IPTV
- Set "Select ISP Profile" to "Manual"
- Set "VID" to "35" and leave "PRIO" set to "0"
nvram set switch_stb_x=0
nvram commitreboot
