Hi
I have an issue with my RT-AC88U : after a while (less than 24 hours) the WiFi connected devices are not able to see each other (no answer to ping/no route to host when trying to SSH in/ERR_ADDRESS_UNREACHABLE in chrome)
I have no issue if I try from a wired connected device
AP isolation is off for both bands
If I turn AP isolation on and off again, it works for a while and then not anymore
Same if I reboot
I tried a factory reset and the same happens
I am out of options, do you have any idea?
Same if I reboot
