RT-AC88U Connection reset by peer
Natey2
RT-AC88U with firmware 3.0.0.4.384_20379
I'm seeing about one of these messages logged every hour in the router's system log:
Jun 27 05:53:46 miniupnpd[929]: upnp_event_recv: recv(): Connection reset by peer
What could be causing it? And how do I find out which device?
(5 wired devices, 3 5GHz connections, 9 2.4GHz connections)
Means that miniupnpd got a RST packet, which basically means the other end hung up the phone as there was not more traffic...
Log noise - if it happens once an hour - do you have a VOIP connection on one of your clients?
It is mostly once an hour, sometimes I see it maybe twice an hour.
Yes, MagicJack connected via USB to Desktop PC wired to router.
Yep, it's probably due a registration event for the MagicJack for inbound calls.
Not much to worry about.
