Cyb3r
I'm using PPPoE mode and this started today for no obvious reason, this is my log:
Feb 27 13:19:20 syslog: WLCEVENTD wlceventd_proc_event(386): eth1: Deauth_ind F0:99:B6:2C:4F:BD, status: 0, reason: Disassociated due to inactivity (4)
Feb 27 13:19:20 syslog: WLCEVENTD wlceventd_proc_event(401): eth1: Disassoc F0:99:B6:2C:4F:BD, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Feb 27 13:19:27 check_watchdog: [check_watchdog] restart watchdog for no heartbeat
Feb 27 13:19:27 rc_service: check_watchdog 379:notify_rc restart_watchdog
Feb 27 13:23:48 syslog: WLCEVENTD wlceventd_proc_event(420): eth1: Auth F0:99:B6:2C:4F:BD, status: 0, reason: d11 RC reserved (0)
Feb 27 13:23:48 syslog: WLCEVENTD wlceventd_proc_event(449): eth1: Assoc F0:99:B6:2C:4F:BD, status: 0, reason: d11 RC reserved (0)
Feb 27 13:23:49 dnsmasq[357]: script process exited with status 20
Feb 27 13:24:27 check_watchdog: [check_watchdog] restart watchdog for no heartbeat
Feb 27 13:24:27 rc_service: check_watchdog 379:notify_rc restart_watchdog
Feb 27 13:25:27 check_watchdog: [check_watchdog] restart watchdog for no heartbeat
Feb 27 13:25:27 rc_service: check_watchdog 379:notify_rc restart_watchdog
Feb 27 13:26:27 check_watchdog: [check_watchdog] restart watchdog for no heartbeat
Feb 27 13:26:27 rc_service: check_watchdog 379:notify_rc restart_watchdog
Feb 27 13:26:29 pppd[32326]: fork failed: Cannot allocate memory
Feb 27 13:26:29 pppd[32326]: Failed to create child process for /tmp/ppp/ip-down: Cannot allocate memory
Feb 27 13:26:29 miniupnpd[24226]: Failed to get IP for interface ppp0
Feb 27 13:26:29 miniupnpd[24226]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Feb 27 13:26:29 wsdd2[495]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Feb 27 13:26:30 WAN_Connection: Fail to connect with some issues.
Feb 27 13:26:30 DualWAN: skip single wan wan_led_control - WANRED off
Feb 27 13:26:30 nat: apply redirect rules error!
Feb 27 13:26:32 pppd[32326]: Connection terminated.
Feb 27 13:26:32 pppd[32326]: Modem hangup
Feb 27 13:26:35 nat: apply redirect rules error!
Feb 27 13:26:40 nat: apply redirect rules error!
Feb 27 13:26:42 pppoe-relay[32322]: PADO packet from 3e:61:04:46:c8:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:26:42 pppoe-relay[32322]: PADO packet from 7a:19:f7:0c:10:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:26:42 pppoe-relay[32322]: PADO packet from 3e:61:04:46:d8:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:26:42 pppoe-relay[32322]: PADO packet from 02:31:46:66:11:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:26:42 pppoe-relay[32322]: PADO packet from 56:4b:8c:8d:de:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:26:42 pppoe-relay[32322]: PADO packet from 7a:19:f7:0b:9c:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:26:42 pppd[32326]: Connected to 3e:61:04:46:c8:f4 via interface vlan881
Feb 27 13:26:42 pppd[32326]: Connect: ppp0 <--> vlan881
Feb 27 13:26:42 pppoe-relay[32322]: PADS packet from 3e:61:04:46:c8:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:26:42 pppd[32326]: PAP authentication succeeded
Feb 27 13:26:42 pppd[32326]: peer from calling number 3E:61:04:46:C8:F4 authorized
Feb 27 13:26:42 pppd[32326]: fork failed: Cannot allocate memory
Feb 27 13:26:42 pppd[32326]: Failed to create child process for /tmp/ppp/ip-pre-up: Cannot allocate memory
Feb 27 13:26:42 pppd[32326]: local IP address 175.110.152.225
Feb 27 13:26:42 pppd[32326]: remote IP address 84.235.68.245
Feb 27 13:26:42 pppd[32326]: primary DNS address 84.235.57.230
Feb 27 13:26:42 pppd[32326]: secondary DNS address 84.235.6.55
Feb 27 13:26:42 wsdd2[495]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Feb 27 13:26:43 pppoe-relay[32322]: PADO packet from 7a:19:f7:0c:20:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:26:45 nat: apply redirect rules error!
Feb 27 13:26:50 nat: apply redirect rules error!
Feb 27 13:27:27 check_watchdog: [check_watchdog] restart watchdog for no heartbeat
Feb 27 13:27:27 rc_service: check_watchdog 379:notify_rc restart_watchdog
Feb 27 13:27:30 nat: apply redirect rules error!
Feb 27 13:27:42 dnsmasq[357]: script process exited with status 20
Feb 27 13:27:45 nat: apply redirect rules error!
Feb 27 13:27:55 rc_service: httpd 372:notify_rc restart_wan_if 0;restart_stubby
Feb 27 13:27:55 miniupnpd[24226]: Failed to get IP for interface ppp0
Feb 27 13:27:55 pppd[32326]: Connection terminated.
Feb 27 13:27:55 miniupnpd[24226]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Feb 27 13:27:55 wsdd2[495]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Feb 27 13:27:56 wsdd2[495]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Feb 27 13:27:58 wan: [wan0_hwaddr] == [2C:4D:54:22:79:88]
Feb 27 13:27:59 pppd[27156]: pppd 2.4.7 started by admin, uid 0
Feb 27 13:27:59 pppoe-relay[27152]: PADO packet from 7a:19:f7:0c:20:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:27:59 pppoe-relay[27152]: PADO packet from 7a:19:f7:0c:10:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:27:59 pppoe-relay[27152]: PADO packet from 02:31:46:66:11:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:27:59 pppoe-relay[27152]: PADO packet from 3e:61:04:46:d8:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:27:59 pppoe-relay[27152]: PADO packet from 56:4b:8c:8d:de:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:27:59 pppoe-relay[27152]: PADO packet from 7a:19:f7:0b:9c:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:27:59 pppoe-relay[27152]: PADS packet from 7a:19:f7:0c:20:f4 on interface vlan881 does not have Relay-Session-Id tag
Feb 27 13:27:59 pppd[27156]: Connected to 7a:19:f7:0c:20:f4 via interface vlan881
Feb 27 13:27:59 pppd[27156]: Connect: ppp0 <--> vlan881
Feb 27 13:27:59 pppd[27156]: PAP authentication succeeded
Feb 27 13:27:59 pppd[27156]: peer from calling number 7A:19:F7:0C:20:F4 authorized
Feb 27 13:27:59 miniupnpd[24226]: Failed to get IP for interface ppp0
Feb 27 13:27:59 miniupnpd[24226]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Feb 27 13:27:59 wsdd2[495]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Feb 27 13:28:00 pppd[27156]: local IP address 142.154.70.10
Feb 27 13:28:00 pppd[27156]: remote IP address 84.235.68.247
Feb 27 13:28:00 pppd[27156]: primary DNS address 84.235.57.230
Feb 27 13:28:00 pppd[27156]: secondary DNS address 84.235.6.55
Feb 27 13:28:15 nat: apply redirect rules error!
Feb 27 13:28:20 nat: apply redirect rules error!
Feb 27 13:28:24 rc_service: httpd 372:notify_rc reboot
Feb 27 13:28:24 pppd[27156]: fork failed: Cannot allocate memory
Feb 27 13:28:24 pppd[27156]: Failed to create child process for /tmp/ppp/ip-down: Cannot allocate memory
Feb 27 13:28:24 miniupnpd[24226]: Failed to get IP for interface ppp0
Feb 27 13:28:24 miniupnpd[24226]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
Feb 27 13:28:25 pppd[27156]: Connection terminated.
Feb 27 13:28:26 iTunes: daemon is stopped
Feb 27 13:28:26 FTP_Server: daemon is stopped
Feb 27 13:28:27 Samba_Server: smb daemon is stopped
Feb 27 13:28:27 kernel: gro disabled
Feb 27 13:28:27 Timemachine: daemon is stopped
Feb 27 13:28:27 WEBDAV_Server: daemon is stopped
Feb 27 13:29:04 syslog: WLCEVENTD wlceventd_proc_event(401): eth1: Disassoc F0:99:B6:2C:4F:BD, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Feb 27 13:30:58 rc_service: httpd 372:notify_rc restart_wan_if 0;restart_stubby
Feb 27 13:30:58 rc_service: waitting "reboot" via httpd ...
Feb 27 13:31:13 rc_service: skip the event: restart_wan_if 0;restart_stubby.
Feb 27 13:32:40 rc_service: httpd 372:notify_rc restart_wan_if 0;restart_stubby
Feb 27 13:32:40 rc_service: waitting "reboot" via httpd ...
Feb 27 13:32:55 rc_service: skip the event: restart_wan_if 0;restart_stubby.
Feb 27 13:34:27 check_watchdog: [check_watchdog] restart watchdog for no heartbeat
Feb 27 13:34:27 rc_service: check_watchdog 379:notify_rc restart_watchdog
Feb 27 13:34:27 rc_service: waitting "reboot" via httpd ...
Feb 27 13:34:42 rc_service: skip the event: restart_watchdog.
Feb 27 13:44:14 miniupnpd[24226]: Failed to get ip address for interface ppp0
Feb 27 13:44:24 miniupnpd[24226]: Failed to get ip address for interface ppp0
Feb 27 13:44:27 check_watchdog: [check_watchdog] restart watchdog for no heartbeat
Feb 27 13:44:27 rc_service: check_watchdog 379:notify_rc restart_watchdog
Feb 27 13:44:27 rc_service: waitting "reboot" via httpd ...
Feb 27 13:44:42 rc_service: skip the event: restart_watchdog.
