RT-AC88U Link Aggregation
Zedoz
Hi
Ive enabled link aggregation in the RT-AC88U option under LAN / SwitchControl / Bonding Link Aggregation. For Bonding Policy setting, is it best to use "Default" option? U can only aggregate Ports 1 & 2?
I connected my 2 x 1Gbps ports on my QNAP NAS to LAN ports 1 & 2 on the router. I then tried the above, but when you look at network map, hard to tell if working, I cant see any change to what I had before
My ISP requires VLANn 2 for an internet connection. I thought link aggregation does not work with VLAN like other routers?
Anyway to test if link aggregation working propely besides doing a file transfer?
I have the lastest Merlin firmware installed
