RT-AC88U - Strange entry in the log
MarcusVR
Hi guys!
I've noticed a strange entry at the log of my RT-AC88U - Merlin's latest stable firmware, 382.1. It is a message related to an app, but I don't imagine what it could be. May someone help me?
Thanks in advance!
Nov 17 21:51:14 kernel: ERR[set_app_info_qos_meta:3335] Failed to find app info entry (6-4-132)!
Nov 17 22:02:12 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 17 22:02:14 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 17 22:02:15 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 17 22:02:15 kernel: ERR[update_qos_data_by_ip:3436] Failed to find udb entry by skb dst-IP!
Nov 17 22:02:16 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 17 22:02:23 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 17 23:00:28 disk_monitor: Got SIGALRM...
Nov 17 23:40:55 kernel: ERR[set_app_info_qos_meta:3335] Failed to find app info entry (11-4-132)!
Nov 17 23:40:55 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 17 23:41:07 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Nov 18 00:10:18 dnsmasq-dhcp[319]: DHCPDISCOVER(br0) ac:5f:3e:df:95:cd
Nov 18 00:10:18 dnsmasq-dhcp[319]: DHCPOFFER(br0) 192.168.1.112 ac:5f:3e:df:95:cd
Nov 18 00:10:18 dnsmasq-dhcp[319]: DHCPREQUEST(br0) 192.168.1.112 ac:5f:3e:df:95:cd
Nov 18 00:10:18 dnsmasq-dhcp[319]: DHCPACK(br0) 192.168.1.112 ac:5f:3e:df:95:cd Cell
Nov 18 00:10:40 dnsmasq-dhcp[319]: DHCPDISCOVER(br0) ac:5f:3e:df:95:cd
Nov 18 00:10:40 dnsmasq-dhcp[319]: DHCPOFFER(br0) 192.168.1.112 ac:5f:3e:df:95:cd
Nov 18 00:10:40 dnsmasq-dhcp[319]: DHCPREQUEST(br0) 192.168.1.112 ac:5f:3e:df:95:cd
Nov 18 00:10:40 dnsmasq-dhcp[319]: DHCPACK(br0) 192.168.1.112 ac:5f:3e:df:95:cd Cell
Nov 18 00:18:08 kernel: ERR[set_app_info_qos_meta:3335] Failed to find app info entry (1-4-193)!
Nov 18 00:22:43 kernel: ERR[set_app_info_qos_meta:3361] It's a paid app, please assign a default bandwidth!
Hi guys!
Thanks in advance!
Set values in the QOS , Manual Settings for Bandwith . Then set it back to Automatic. All the stupid errors disappear like magic.
And magically they reappear after some time.... this router seems to be full of flakyness. I also lost ethernet ports 5-8 :-(
Did you factory reset after you flashed to 382.1 stable?
Nope, thats one step i didnt do. It was powered down and restarted a number of time . Do I need to do more ?
In this case yes. You have problems that others have had and fixed. Do a factory reset and slowly add settings back in a way that would reveal the problem. Seriously this is the best advice in your case. It will give you a starting point. The latest alpha is also worth your try as well.
That didnt help much to be honest.
Shows the following :
LAN 4
1
1000 Full Duplex
B0:93:5B:B4:XX:XX
LAN 5 (RTK)
NA
Unplugged
<unknown>
LAN 6 (RTK)
NA
1000 Mbps
<unknown>
LAN 7 (RTK)
NA
Unplugged
<unknown>
LAN 8 (RTK)
NA
Unplugged
<unknown>
Everything else is working OK.
LAN 4
1
1000 Full Duplex
B0:93:5B:B4:XX:XX
LAN 5 (RTK)
NA
Unplugged
<unknown>
LAN 6 (RTK)
NA
1000 Mbps
<unknown>
LAN 7 (RTK)
NA
Unplugged
<unknown>
LAN 8 (RTK)
NA
Unplugged
<unknown>
Ok I tried to look this up and I found this.
https://www.snbforums.com/threads/rt-ac88u-4-ports-not-working.28617/
In this thread one fellow advised to power off, unplug power, power on to release stored energy(not plugged in at this point yet) plug in power on. It worked for a couple guys. Your model is predisposed to have this problem it would seem.
