Gouldin
Been struggling for the past couple of weeks to get QOS working in any meaningful way on my router, Running 380.65_4 or the new .66 beta's.
None of the QOS modes or rules appear to adhere to the upload rules, so my xbox one swamps the entire internet connection.
My Internet speeds are 24mb down and 555kbps up (terrible I know...)
For adaptive qos, if I set 18 down and 0.4 up, my xbox still uploads way past the threshold and effectively kills the connection.
If I try traditional qos, no device appears to get capped.
Bandwidth limiter doesn't do much either, even with 0.1 upload set on it.
On my old N66u from several years ago, it used to work a treat, so was just wondering if anyone knew which firmware has working QOS on it for the AC88U?
