Hi All,
Just received a replacement for my RT-AX86S as it is only 6mths old and I have been seeing random restarts that I just could not track down - nothing in the logs apart from the normal router boot process. I had this issue across different firmware versions and it slowly started to increase in frequency.
Anyway, the new unit has a different power adapter. The original has an external 'brick' and the new one an integrated one so I am now thinking that the issue I had was simply a faulty power unit that was causing the issue.
So to any other folks having this issue. check the power supply! (can't believe I never even considered this)
