Solved RT-AX86U dead WiFi asking for country code?
Hello, stumbled upon this thread and my AX86U was having the exact same issues as described here and in multiple thread:
  1. Could not login with my usual credentials
  2. Reset to default and tried to use it as a mesh node (I bought a new AX86U Pro) but it couldn't join.
  3. Tried in AP mode, Wifi not working with country code error.
I have no backup settings of the router unfortunately. I hear that @ColinTaylor may be able to help? What do I need to do to help restore this router?
Also it seems to be a widespread issues and pretty concern it will also affect my new AX86U Pro. Other that , I have disabled G
the update to prevent this issue has been released for the pro for a while now. if you installed it you'll be ok.
as for the AX86U it got the update a lot later (two days ago). it seems to be one of the most affected models. i hope Mr., Colin can help you, but from what i understand of you don't have a back up you have a better chance by contacting asus support.
Install the current AX86U Pro firmware 3.0.0.6.102_34336... it has been patched... Hard Reset and configure from scratch.
FW Reset FAQ
Reset button/webUI Restore/node removal clears settings in NVRAM; reboot restores fw defaults from CFE
Hard Reset via WPS button/webUI Restore+Initialize also clears data logged in /jffs partition
Me, I would still avoid using the ancillary router features that permit WAN access, like AiCloud, etc.... keep it simple and as locked down as you can. This approached has avoided this current WAN vulnerability.
OE
It's Thanksgiving morning, I just got home from the traditional high school football rivalry game - we won, turkey's in the oven, family is happy, life is good. So I decide to update my Asus RT-AX86U. Why not, it's been over 2 years since I updated it. Loaded the latest version; went well but unable to log in. Asus says do a Re-Set. No problem. Now the dreaded "The Country Code is not exist" and...
NO WIFI. NO Macy's parade. NO football. NO "Alice's Restaurant" and NO dinner music. I explained to my family what happened, NO sympathy. My chance of escaping this day unscathed is less than that of the turkey.
Hardwired my PC and started shopping for Black Friday deals on new routers. And then I found this post. Could there really be a guy that can fix this? And he does it just because he's a good guy? So I sent him a message. In no time I'm back to goodness. Amazing. My family doesn't care that some good-hearted guy on the internet solved the problem because Dad ruined Thanksgiving. Oh well. The cat still seems to like me.
So my vote for "Internet Man Of The Year" goes to @ColinTaylor. I can't thank you enough. Happy Holidays!
Hello all, just a little update on my AX86U router. I reached out to @ColinTaylor and he kindly let me know what I need to provide to try to fix it. Fortunately, the strange thing is my AX86U wifi was fixed after I messaged him, thus I didn't have to trouble @ColinTaylor and take up his time!
While getting the details he needed, I turned off the router, turned it back on, entered into admin to enable Telnet, but lo and behold, when I checked the wifi settings, the country code error disappeared and the wifi started working again! And my AX86U Pro can finally detect it as a node! The only thing I did differently was to update to the new firmware a couple of days ago but I did not switch it off after the update then. Could it be that updating to the new firmware and then switching it on/off might have fixed the wifi + country code issue as well?
Anyone else to confirm the current 3.0.0.4.388_24323 firmware for RT-AX86U/S fixes the missing configuration issue?
So the first was as above (eugineispeanut) #1
This person is another success story it seems (momo3690) #2
And this one (paliyoes) #3
And this one (ohbreeeezy) #4
It's looking positive... 👍
If this is what Asus managed to achieve with firmware update - worth the wait and problem solved. Unfortunately, many affected customers perhaps had to buy a new router to keep their networks going. I expect cheap RT-AX86Us coming on the second hand market as a result.
Hi, I got an RT-AC86U that was flashed with Merlin and lost the partition containing the WiFI data, two years ago, at that time I didn't found any solution so I've been using it as LAN router only alongside another as repeater for the WiFi, and recently found this thread. Do you think the solution used on the AX models could work on recreating the partition on an AC model?
The recent asus firmwares have repaired the vulnerability, and in some cases have been said to repair that partition. May be worth a try?
It might be possible if you have a "Save settings" file (Administration - Restore/Save/Upload Setting) that was created before the problem occurred. Although I'm not very familiar with your particular model.
@Ripshod Thanks for the suggestion wasn't aware ASUS still released an update for the model, tried it also did a factory reset and a hard reset but the partition wasn't restored, the WiFi still dead and ask for the country code each time it opens Wireless-General tab.
@ColinTaylor Unfortunately I got the device after the original owner flashed the firmware, and didn't ask for any backup, no worries at least I know the device wasn't faulty and only lost the partition storing the data to make the WiFi work, thanks regardless.
I just made this account to say that the ASUS RT-AX86 Series(RT-AX86U/RT-AX86S) Firmware version 3.0.0.4.388_24323 solved the problem.
Previously I had the latest version of Merlin but a power outage caused this problem (asking for country code). Fortunately I was able to login onto the web interface and apply the "new" firmware.
@ColinTaylor : Hi Colin, got issue with RT-AX82u, after latest update 3.0.0.4.388_25017 something went wrong, both radios were dead. I managed to put previous version, which was fine ( 3.0.0.4.388_25004 ), 2.4GHz back, but no 5GHz.
When i select 2.4GHz drop down menu, all fine, but when select 5GHz it says country code missing. Other than that, no errors, turning 5GHz on, off, setting it, just no 5GHz led and of course, no 5GHz SSID. I even restored old config backup from 2021, no help. MAC addresses are fine, both ok, no zeros. Is there any way to restore it back? After I sshed to router, I have dumped nvram, opened it in vi editor, read thru and found ccode=US line, but obviously, it missing somewhere else. Didn't change anything and just closed vi editor and log out. Sorry for long post...
Hi guys im from argentina. I have a RTAX86u and my wifis deads. Could you help me ? I saw @ColinTaylor could help me. Thanks in advance
I use stock version.
Current Version : 3.0.0.4.388_24243-g3b611ea
Manual firmware update : Upload
and my wifis deads
Would you be able to provide error messages or further details please?
This thread is primarily for those seeing a specific error message, but we could point you to other possible solutions (threads) if it is a different issue.
Thanks a lot Mates, yes i had do a factory reset (power cut) and then it shows ""The Country Code is not exist!"" with 3.0.0.4.388_24243 then I upload (manually) to 3.0.0.4.388_24323 it fix this error. Is this permanent or has Asus not released a patch yet? Every time I do a factory, will this problem return with the latest stock or Merlin version? Giga Apreciated friends!
