RT-AX86U Pro - Restrict IoT Network
mm1
Is there a way to disable Internet access for the IoT Network in the "Guest Network Pro"? I use the default Asus Firmware 3.0.0.6.102.
If you have the Guest Network Pro IoT set to use Same subnet as main network, try using the Parental Control section to block internet access to specific devices.
Otherwise not seeing a way, in a quick look, to block it for all IoT devices at once. Overall the Guest Network Pro has its issues and this may just be one more to add to the list.
