Solved RT-AX86U_PRO 388.1 and Wireguard Server
fbriceno97
Hi, I'm trying to setup a Wireguard Server using Asus port on 388.1, but I cannot get my device to connect
I already have a raspberry piacting as a Wireguard Server (using a different port), working without any issues, but I'd love to have a backup.
I have enabled the Wireguard Server in the router, keeping Wireguard 51820 port, I even opened up this port for the router, thinking that it might be blocked, but so far nothing.
Do I need to add special rules under VPN director to allow the own Wireguard Server to interact with the clients?
Thanks for your help and guidance!
I finally found the problem and got it working, I had opened a wide range of UDP ports for my Nintendo switch and it was taking priority over the wireguard port of the router. Once I removed the nintendo switch port forwarding, the wireguard server worked properly!
