RT-AX86U_PRO_3004_388.8_4 firmware MD5 checksum mismatch
inakaya
Hi All
So I've downloaded the RT-AX86U_PRO_3004_388.8_4 firmware (I'm on RT-AX86U_PRO_3004_388.8_2 and saw there was an update available)
Running a MD5 checksum either from my portable apps, or online, doesn't give a match for the sha256sum.sha.256 value in the zip; namely
MD5 from app/online - f7aad9ac4b5b73f9bc160e55fca25b12
sha256sum.sha.256 zip file value - 67a28f4e316f070206c1616d7af270866d9aad69d08334edb864e4e0c424640a (which get's truncated as emboldened see snips).
Downloaded a few times and no different...and obviously do not want to install until they match.
Can anyone shed any light on it (probably my schoolboy error; although not sure what I am doing wrong as this has worked previously)?
Thanks in advance if anyone can suggest an answer.
If you're on Linux, run ha256sum -c sha256sum.sha256 on the files in the zip, and you will see OK. The value in sha256sum.sha256 in the zip is the same as the one on the website.
Running a MD5 checksum either from my portable apps, or online, doesn't give a match for the sha256sum.sha.256 value in the zip; namely (...)
It looks like you're running an MD5 checksum, while you need to run an SHA-256 checksum instead. In fact, I've just tested both options, and I'm pretty sure that's the problem. Can you please try the SHA-256 checksum?
@inakaya, FYI there is a specific subforum for Asus-Merlin firmware discussion and issues:
The SHA-256 hash checks out fine (matches) for me.
bennor - Apologies for posting in the wrong place. I have to admit I do it a lot. Happy for this post to be deleted as think the md5 vs. sha256 must be my problem.
Fernando - Sorry for being a complete idiot and not thinking of that!
