Phil Outram
Hi
I have a couple of problems with my RT-AX88U running firmware version 384.10:
1) After several days of uptime (between 4 and 6) the WAN becomes disconnected and there is no internet access. I have a draytek vigor 130 modem connected to a vdsl ppoe service. Rebooting the modem resolves the fault, which then occurs again after a few days. This does not occur with either the stock firmware or another router connected to the same modem.
2) After several days the router no longer obtains any updated AI protection definition updates. Performing a manual check on the definitions reports that it is the latest version, however if you reboot the router then it will update to a later version.
Does anyone else experience the same issues?
