RT-AX88U craps out doing MiniDLNA
  • Thread starter Deleted member 66328
  • Start date
D
Guest
So I fixed my earlier issue (check my thread)
But now my router RY-AX88U cannot even flow MiniDLNA to my LG TV with out it buffering
I was playing a 4k stream (Planet Earth 2)
I have an ext4 drive with a REMUX or such, and it buffers. My 68 never did. We're doing 5G/866 on the drive. It just froze for alomst two seconds.
.My RT-AC^*68 had no issues.
I Had a bunch of issues with this router, when I reformatted my second drive ext4, many of those have fixed itself.
Before you tell me things I have already done,
I have rebooted my TV
I have rebooted my router
This same drive did not flake out plugged into my RT-68AU and buffered
Both connected at 833mbps
I am not asking you to what to reboot, I am asking you what logs I can check to find out why ^^ may be happening.
I watch pretty much every other stream (480p, 720ps, blah blah) works fine.
I put said REMUX as a USB in the TV, no issues either)
I'm still having issues with my LG OLED getting 833 signal 5G buffering when my RT-68AU did not have issues. What logs can I check to fix this?
If you reply with - reboot your router-
I have done such,
Is airtime fairness enabled, I've found that kills streams and skype/ anything that requires consistent throughput.
Have you tried factory defaults and setting it up as new. Not restoring from config backup file.
"I am not asking you to what to reboot, I am asking you what logs I can check to find out why ^^ may be happening."
Not what you want to hear, and MY opinion but shared by many......
But, you could use your router, just as a router and get a streaming device, and use it to stream :)
What is the CPU utilization during the streaming issues?
What are the NHD platforms? Are you thinking of HND (RT-AC86U and RT-AX88U)? :)
Still had issues - installed Asus firmware - all my problems went away. Back to 800+mbps speed tests.
I will miss the ad block, but done with Merlin with the 88U. Always was solid with the 68u.
