RT-AX88U firmware 388.1 restart issue
davemcwish
Not sure if this is the best place to post this. If not, would a Mod advise where it should?
My router which was been very stable with the merlin firmware played up last night. Here's the start of the log. Does anyone know how/why it restarted. I should add that my TV and Sky Q both had issues after the unattended restart. Luckily a manual reboot resolved the issue.
Feb 5 19:36:50 ntpd: Initial clock set
Feb 5 19:36:50 rc_service: ntpd_synced 1963:notify_rc restart_diskmon
Feb 5 19:36:50 disk_monitor: Finish
Feb 5 19:36:50 disk_monitor: be idle
Feb 5 19:36:52 kernel: SHN Release Version: 2.0.2 36f59aa
Feb 5 19:36:52 kernel: UDB Core Version: 0.2.20
Feb 5 19:36:52 kernel: Init chrdev /dev/idpfw with major 191
Feb 5 19:36:52 kernel: IDPfw: flush fc
Feb 5 19:36:52 kernel: IDPfw: IDPfw is ready
Feb 5 19:36:52 kernel: sizeof forward pkt param = 280
Feb 5 19:36:52 BWDPI: fun bitmap = 4ff
Feb 5 19:36:52 wlceventd: wlceventd_proc_event(505): eth7: Auth 6A:07:C6:1A:30:27, status: Successful (0)
Feb 5 19:36:52 wlceventd: wlceventd_proc_event(534): eth7: Assoc 6A:07:C6:1A:30:27, status: Successful (0)
Feb 5 19:36:52 hostapd: eth7: STA 6a:07:c6:1a:30:27 IEEE 802.11: associated
Feb 5 19:36:52 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Feb 5 19:36:52 hostapd: eth7: STA 6a:07:c6:1a:30:27 RADIUS: starting accounting session 2ACBB15AF56DC568
Feb 5 19:36:52 hostapd: eth7: STA 6a:07:c6:1a:30:27 WPA: pairwise key handshake completed (RSN)
Feb 5 19:36:52 wlceventd: wlceventd_proc_event(469): eth7: Deauth_ind 58:B0:3E:A6:BF:04, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Feb 5 19:36:52 hostapd: eth7: STA 58:b0:3e:a6:bf:04 IEEE 802.11: disassociated
Feb 5 19:36:52 dnsmasq-dhcp[1186]: DHCPREQUEST(br0) 192.168.1.26 6a:07:c6:1a:30:27
Feb 5 19:36:52 dnsmasq-dhcp[1186]: DHCPNAK(br0) 192.168.1.26 6a:07:c6:1a:30:27 address in use
Feb 5 19:36:53 kernel: bcm_i2c: bus 0: Failed to detect SFP: 100 retries exhausted
Feb 5 19:36:53 wlceventd: wlceventd_proc_event(486): eth7: Disassoc 58:B0:3E:A6:BF:04, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Feb 5 19:36:53 hostapd: eth7: STA 58:b0:3e:a6:bf:04 IEEE 802.11: disassociated
Feb 5 19:36:54 A.QoS: qos_count=0, qos_check=0
Feb 5 19:36:55 wlceventd: wlceventd_proc_event(486): eth7: Disassoc 6A:07:C6:1A:30:27, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Feb 5 19:36:55 hostapd: eth7: STA 6a:07:c6:1a:30:27 IEEE 802.11: disassociated
Feb 5 19:36:56 dnsmasq-dhcp[1186]: DHCPDISCOVER(br0) 6a:07:c6:1a:30:27
Feb 5 19:36:56 dnsmasq-dhcp[1186]: DHCPOFFER(br0) 192.168.1.27 6a:07:c6:1a:30:27
Feb 5 19:36:57 rc_service: ip-up 1809:notify_rc stop_samba
Feb 5 19:36:57 rc_service: ip-up 1809:notify_rc start_samba
Feb 5 19:36:57 rc_service: waitting "stop_samba" via ip-up ...
Feb 5 19:36:57 wsdd2[1285]: Terminated received.
Feb 5 19:36:57 wsdd2[1285]: terminating.
Feb 5 19:36:58 bsd: bsd: Sending act Frame with transition target eth7 ssid 24:4b:fe:0a:8d:b4
Feb 5 19:36:58 Samba_Server: smb daemon is stopped
Feb 5 19:36:59 wlceventd: wlceventd_proc_event(469): eth6: Deauth_ind 42:92:55:B7:7C:10, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3)
Feb 5 19:36:59 hostapd: eth6: STA 42:92:55:b7:7c:10 IEEE 802.11: disassociated
Feb 5 19:36:59 rc_service: ip-up 1809:notify_rc stop_samba
Feb 5 19:36:59 rc_service: waitting "start_samba" via ip-up ...
Feb 5 19:36:59 dnsmasq[1186]: exiting on receipt of SIGTERM
Feb 5 19:36:59 dnsmasq[3377]: started, version 2.85 cachesize 1500
That is the first line from the log for that day the prior lines are from May 5. Thanks though. I guess it's an unexplained if what I showed is just a restart.
And give us some more information, like plugins in AMTM for instance.
I had a spontanious reboot issue sometimes with the conmon plugin.
You said the problem occurred "last night", the 10th Feb. So we'd need to see the messages for 10th Feb, not 5th Feb.
Sorry for the confusion as I copied this from another forum and was redirected here. The incident happened on Feb 5 and I posted everything from the start of the log.
OK. Are you sure what you posted was from the beginning of the log? When the router reboots its date and time are temporarily reset to 5th May 2018. If you scroll back past that section you should see the log entries from before Feb 5 @ 19:36.
