Max33Verstappen
Just some joke, seeing so many guys desperately seeking the difference between these 2.
A1.1 IDLE atHow about this...(just guess)
A1.1 is actually a cost cutting measure, so it got more integrated components used than A1, thus turning on this CPU idle feature to offset the thermal. (This conjecture can somewhat explain why ASUS re-enabled it on specific revision later on)
Why don't you guys try ‘pwr config --cpuwait off’ on the A1.1 to see its thermal performance.
I will post soon. BTW one clear difference between A1 and A1.1 is the thermals. A1 CPU idles at 75° C and both my A1.1 CPUs idle at 58° C. Can anyone confirm this?
don't believe a hardware revision is going to drop temps 17c.
As I mentioned before, Asus disables CPU idling on HW revision 1.0.
Yes. But no one knows why.So 1.0 has it disabled by default and 1.1 its enabled by default?
Yup A1 units have poor thermals compared to A1.1.
Yes Wifi6 certification is only for A1.1 model. I don;t know if it makes A1 model Wifi6 compliant automatically.
Nope. All is well since 1 month.Has anyone been running an A1 with cpuwait on? Any issues or notice performance drop?
CPU wait turned on and all is well since 1 month. Sorry if my previous reply was not clear.So you have turned on cpuwait? But confused by your answer. Just confirming.
I agree, the thermals are likely fine.
I've been running with cpuwait turned on since last july in my RevA1 AX88 without issues caused by cpuwait. (I have been able to reproduce every issue I've had in this period without cpuwait also)
Just type this in sshAny how do you enable it? A manual command added to init script?
pwr config --cpuwait on
This way it is disabled after every reboot. To make it permanent, add it to init script.Code:pwr config --cpuwait on
Welcome To SNBForums
