zacofunny
Hi.
I'm experiencing issue while using LAN Link Aggregation. The problem is that WiFi stops work properly, i.e. both the networks 2.4G and 5G are visible for clients, however router doesn't accept clients during authorization.
Sometimes everything works with no issues until another restart router or switch (TP-Link TL-SG3424) that is connected to it. The problem disappears either when I disable Link Aggregation or when I unplug one of the wires from switch (without disabling Link Aggregation).
@RMerlin is this a known problem and is there any solution?
It looks strange for me that Link Aggregation and WiFi authorization is related in any way and it seems that there may be some bug in the firmware causing this issue.
I'm using 384.19
LAN - Switch Control settings:
Jumbo Frame = Disabled
Spanning-Tree Protocol = Enabled
Bonding/ Link aggregation = Enable
I disabled WiFi Smart Connect option so I manage 2.4G and 5G manually.
The link aggregation is made between TL-SG3424 switch and LAN ports 1 and 2 of the router.
I'm using 384.19
